just got my car done and gotta question...
Old Nov 30, 2007 | 04:17 PM
T9U4ReBgO's Avatar
Default just got my car done and gotta question...
ok i just got my car boosted and driving and was just curious about y it kinda bucks...like when i am crusing and just have enough gas to maintain speed it jerks...i am untuned with stock injectors and the only pounding on it i did was half throttle 2nd gear till it got into a lil boost to make sure my bov worked and it was getting into boost...im running open dp and have one cel light one for o2...is it doing this bc it is untuned...
Old Nov 30, 2007 | 04:31 PM
JaredKaragen's Avatar
Default Re: just got my car done and gotta question... (T9U4ReBgO)
your 02 cel is causing ti to run poorly. Get a DP on it pronto. your car will have a solid CEL, and will be in limp mode when it realizes the o2 aint workin.
bucking is 99% chance of being the TPS out of calibration. check it's calibration and get back with us.
and how is your car getting more fuel under boost?
Old Nov 30, 2007 | 04:43 PM
hotrod99's Avatar
Default Re: just got my car done and gotta question... (JaredKaragen)
your just asking for it driving it untuned....get some kind of ems and have it tuned asap.
Old Nov 30, 2007 | 04:52 PM
T9U4ReBgO's Avatar
Default Re: just got my car done and gotta question... (hotrod99)
I'm driving it real easy and not goin into boost and plan on getting tuned in a week or so....
Old Dec 1, 2007 | 03:11 AM
T9U4ReBgO's Avatar
ttt
Old Dec 1, 2007 | 07:59 AM
Clayton's Avatar
H-T Administrator
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 &raquo;</TD></TR><TR><TD CLASS="quote">your just asking for it driving it untuned....get some kind of ems and have it tuned asap.</TD></TR></TABLE>
That pretty much sums it up. Get it tuned and your issues will likely be solved.
Old Dec 1, 2007 | 09:34 AM
T9U4ReBgO's Avatar
Default Re: just got my car done and gotta question... (Clayton)
well i understand that and i am driving real careful not getting into boost what so ever...but im not gonna be able to get tuned till next weekend and this is my DD so will it be ok to drive real easy??
Old Dec 1, 2007 | 11:10 AM
coneheadsracing's Avatar
Are you even going to listen to what anyone says? You already have the kit on there, which tells me your going to drive it regardless.... so good luck.
Old Dec 1, 2007 | 11:21 AM
T9U4ReBgO's Avatar
Default Re: just got my car done and gotta question... (coneheadsracing)
i understand what everyone is saying and that wasnt my question...i was just asking if i stay OUT of boost will it be ok to drive till next weekend...yes or no?...if not could i unhook a piece of ic pipe and drive it like that?...thanks
Old Dec 1, 2007 | 11:30 AM
If your going to unhook anything unhook the wastegate. If you unhook your charge pipe, it will prevent the engein from seeing boost, but your turbo will spool up like a ****. Will the engine last sure...... no one knows. You need to get an exhaust on it, get rid of the cel, and get it tuned.
Old Dec 1, 2007 | 11:43 AM
T9U4ReBgO's Avatar
thanks man that was an answer i was looking for...im getting exhaust on it this week and that will eliminate the o2 CEL....i didnt know open downpipe was harmful...anyways what u mean unhook the wastegate?....thanks again
Old Dec 1, 2007 | 12:27 PM
welfarepc's Avatar
he means take the wastegate arm and detach it from your wastegate flap that way all the exhaust blows by and doesnt make boost.
and to answer your question...
my tuner doesnt even want me driving my car for 5 minutes to get to his dyno... i wonder what he would think of my intelligance if i told him i was going to drive it for a week on stock injectors? haha
Old Dec 1, 2007 | 01:19 PM
T9U4ReBgO's Avatar
Default Re: (welfarepc)
ok...im on here to learn as much as possible but i just havent figured out what is so harmful about driving my car and not getting into boost at all...i mean without going into boost my motor is exactly the same as it was not turboed...right?...like i said im just here to learn so someone please help...
Old Dec 1, 2007 | 02:13 PM
Default Re: (T9U4ReBgO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">ok...im on here to learn as much as possible but i just havent figured out what is so harmful about driving my car and not getting into boost at all...i mean without going into boost my motor is exactly the same as it was not turboed...right?...like i said im just here to learn so someone please help... </TD></TR></TABLE>
You will not likely hurt your motor. However, driving with no exhaust and thus no o2 is going to make the motor run fairly rich. Short term not likely to hurt anything, long term you could.
You have to realize the majority of the people in here, have heard it all before. I was only going a week or two without boost, *you said yourself you already boosted it* i didn't have enough money i couldn't afford a tune, so on and so forth. It's just so cheap and easy to have a base map on your car when you boost, that there is no reason to do it the way you are, especially on a DD. No biggie, just unhook the waste gate arm, and you won't have to worry about boost, as much. Good luck.
P.S. no smart tuner would tell you that doing this would be a good idea, because when **** happens people are too quick to point fingers.
Old Dec 1, 2007 | 03:16 PM
T9U4ReBgO's Avatar
Default Re: (coneheadsracing)
no...i have the money to get everything done its just time...i work 3rd shift so its kinda hard..imma try and get my exhaust done monday morning and fuel pump and tune done next week...thanks again for the info now here is a pic of my setup please explain the wastegate thing lol....
here is a close up
see if u can tell me by this pic...thanks
Old Dec 1, 2007 | 03:43 PM
A.E Motoring's Avatar
just take the damn spring out of the wastegate
Old Dec 1, 2007 | 04:39 PM
T9U4ReBgO's Avatar
Default Re: (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">just take the damn spring out of the wastegate</TD></TR></TABLE>
ok like i said im here to learn...y the attitude...but thanks for the help
Old Dec 1, 2007 | 05:03 PM
DA_HONDA_BOY's Avatar
everbody trying to say is take the WG off
just drive it and don't come in to boost you'll be alright
Old Dec 1, 2007 | 05:46 PM
T9U4ReBgO's Avatar
Default Re: (DA_HONDA_BOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_HONDA_BOY &raquo;</TD></TR><TR><TD CLASS="quote">everbody trying to say is take the WG off
just drive it and don't come in to boost you'll be alright</TD></TR></TABLE>
Thank u that's the answer I needed right there...that's all I was asking was if it would be ok to drive like that....
Old Dec 1, 2007 | 10:59 PM
GSR in progress 96's Avatar
* B A N N E D *
Stop driving it until you get it tuned
Old Dec 2, 2007 | 12:44 AM
StockDC2's Avatar
Default Re: (GSR in progress 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR in progress 96 &raquo;</TD></TR><TR><TD CLASS="quote">Stop driving it until you get it tuned</TD></TR></TABLE>
Exactly, not that freaken hard... Ride the bus or something .
Old Dec 2, 2007 | 12:59 AM
Mfoehrkolb's Avatar
Default Re: (StockDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly, not that freaken hard... Ride the bus or something . </TD></TR></TABLE>
--- 3rd shift, taking a bus. I think that would be kinda hard. I personally would rather blow a LS up before taking a bus that late at night. He probably in some crappy town, get shot/shanked for his launch money, and all day bus pass.
Old Dec 2, 2007 | 03:38 AM
T9U4ReBgO's Avatar
Default Re: (Mfoehrkolb)
Ha the bus...imma just keep driving out of boost and see how it works....
Old Dec 2, 2007 | 07:28 AM
b20vtechb's Avatar
even if you don't technicly hit boost you are still flowing CONSIDERIBLY MORE air at part throttle 10"-0" then you where n/a, thus the bucking and over all running rough ... take the wastegate spring out till its getting tuned!
Old Dec 2, 2007 | 08:30 AM
T9U4ReBgO's Avatar
Default Re: (b20vtechb)
ok ill take the wastegate spring out today....so thats gonna make it not hit any boost what so ever but should still run ok....correct...
