DOHC ZC Question!?!
Old Nov 30, 2007 | 01:14 PM
CRXDaddy78155's Avatar
Default DOHC ZC Question!?!
I just got a DOHC ZC motor for my 1990 CRX SI and it just got it shipped...but the mechanic is telling me that I may want to get a new:
Water Pump
Timing Belt
Gasket Kit
while the motor is still out of the car. I have no problem with doing that but I called my local Honda dealer and they said the timing belt is not the same as the SOHC. What motor do I tell him I need parts for? After explaining the same thing to him, even the guy at the Honda Parts was unsure. I'm trying to avoid special ordering the wrong parts for this ZC. Can anyone help?
Old Nov 30, 2007 | 01:28 PM
djmesican's Avatar
Default Re: DOHC ZC Question!?! (CRXDaddy78155)
Part Part Number Application Vendor Notes
ODB0 Distributor TD03U 88-89 Integra .
ODB0 Distributor Cap 30102-PM7-305 88-91 CRX Si/88-89 Integra OEM .
. JP936 . WELLS .
. 44-9620 . VALUCRAFT .
. JP936G . GOLD .
. 8290 . MSD w/Coil Bypass .
OBD-1 Distributor Cap and seal
1994-2001 Integra LS & RS B18 non vtec models.
OBD-1 Distributor Cap part #
OEM Acura - 30102-P54-006 -- listed price through Majestic Acura is $21
Distributor Cap gasket
OEM # 30132-PM5-A02
Rotor Button
88-91 Civic/CRX // 88-89 Integra
Brand-----Part#
OEM - 30103-PM5-A05
WELLS - JP923
VALUCRAFT - 33-8220
Spark plug wires
88-89 Acura Integra
Spark Plug Wires
Brand-----Part#
OEM -
MSD - 32339
MAGNECOR - 45125
NGK - NGK-HE48
NOLOGY - 011014011
**If not going for High performance wires USE OEM all others are inferior except for performance wires.**
Spark plugs
Dont waste your money on platinums or iridiums
NGK is standard from Honda. If your Boosting the motor choose your type carefully as a standard plug is not for you, you will need a colder plug.
Spark Plugs
88-91 Civic/CRX si 1.6L // 88-89 Integra
Brand-----Part#
NGK V-POWER - BCPR6E-11
Spark plug tube seals
86-89 Integra
OEM # 12342-PT2-000
Distributor O- ring and CPS O-ring
88-89 Integra
OEM # 30110-PA1-732
Oil Filter
The S2000 OEM Filters will work also and are made by a reputable company in Japan that makes high performance oil filters, but you will pay more for them.
MY Suggestion...Get OEM Its only a couple bucks so why buy others when you can have a OEM filter for mostly the same price.
Oil Filter
Brand-----Part#
OEM -
STP - S2808
FRAM - PH6811
K&N - HP-1004
MOBIL - M1-104
Cylinder Head Gasket
1988 & 89 Integra
Brand-----Part#
OEM - 12251-PM7-003
FELPRO - 9451PT-1
HKS GROMMET - 2302-RH001 (0.7mm Thick/76mm Bore/9.9 CR)
HKS BEAD - 2301-RH010 (0.6mm Thick/76mm Bore/10 CR)
Head StudsARP
Part # ARP 141-4204 Dodge Neon SRT-4
Head Studs
Brand-----Part#
ARP - ATP6.760-1lb ?? * needs verifying for 100%
Intake Manifold Gasket
1988 & '89 Integra
Brand-----Part#
OEM - 17105-PG6-S00
FELPRO - MS93362
IACV (Intake Air controll valve)
88-91 Civic/CRX
oem # 36455-PT3-A01
Exhaust Manifold Gasket
1988 & '89 Integra
Brand-----Part#
OEM - 18110-PG6-003
FELPRO - MS93363
Rear Main Seal
1988 & 89 Integra
Rear Main Seal
Brand-----Part#
OEM - 91214-PH1-013
Front crank seal
1988-89 Integra
Front Crank Seal
brand-----Part#
OEM - 91212-PEO-662
Cam seals
1988-89 Integra
Cam Seals
brand-----Part#
OEM - 91203-PG6-013
Oil Pan
88-89 Integra
Oil Pan
Brand-----Part#
OEM #
Oil Pan Gasket
Brand-----Part#
OEM - 11251-P01-004
FELPRO - OS30542R
ROL - OS5725
Header
88 - 91 CRX/Civic Headers will fit. The ports are off just a tad but the bolt pattern is money. Nothing a little grinding can't fix.
Timing Belt
1988 Prelude 2.0 Si.
Timing Belt
Brand-----Part#
OEM - 14400-pk2-004 NOTE:I have heard people get part #14400-pk2-003
they should be the same
Timing belt tensioner
OEM part # 14510-PM7-004
Engine and tranmission Mounts
1988 - 1991 CRX/Civic (All trim levels)
Engine and transmission Mounts
Brand-----Part#
OEM - 50810-SH3-040 (Rear, Firewall Mount)
OEM - 50805-SH3-040 (Transmission Mount)
OEM - 50821-SH3-040 (Side Mount, By Timing Belt)
OEM - 50840-SH3-000 (Front Mount)
CPS (Cylinder Position Sensor)
1988 & 89 Integra 1.6l
Brand-----Part#
OEM - 37841-PG7-006
Transmission
Any 88-91 L3 transmissions will work.
**See below for more info**
Throttle Body
88 - 91 Civic/CRX Si 1.6L
Throttle Body Gasket
88-91 Civic/CRX Si 1.6L only
Brand-----Part#
OEM - 16176-PM6-S00 or 16176-PM6-000
Radiator Hoses
*Upper: 88-89 Integra
*Lower: 88-91 Civic/CRX
Radiator Hoses
Brand-----Part#
OEM Lower Hose - 19502-PM3-000
OEM Upper Hose -
Valve cover Gasket
86-89 Integra
Valve Cover Gasket
Brand-----Part#
OEM - 12341-PM7-000
86-89 Integra
Valve cover stud Grommets
90-93 Integra 1.8L
**OEM part # 90442-PR3-000
Valve Cover Studs (outer and 1 in Center)
1990-93 Integra B18, 97-2000 CR-V B20
Valve cover Studs
Brand-----Part#
OEM - 90012-PM7-000 (this is the outer ones)
OEM - (I need the inner stud part #)
Thermostat
88-91 CRX/Civic
Thermostat
Brand-----Part#
Stant OEM TEMP - 45878
Prestone OEM TEMP - 392180
Alternator
88-91 CRX/Civic
Alternator
Get a NAPA if you must use other than OEM, but try to stay OEM here if you can. Advance and Autozone and most other parts stores Have VERY LOW quality replacements...**Why do you think they have to offer a lifetime warranty??..( a little something to make you think)
Brand-----Part#
OEM - 31100-PM8-A03RM or 31100-PM8-A03RMD
Water Pump
88-91 CRX/Civic
Water Pump
Brand-----Part#
OEM - 19200-P01-003 or 19200-P01-004
Water Pump Gasket
*If your gasket is leaking You might as well get a new pump and it will come with the gasket*
Oil Pump
88-91 Civic/CRX
OEM # 15100-P06-A01
Fuel Injectors
88 - 91 CRX/Civic Si / 86-89 Integra
Fuel Injector
Brand-----Part#
OEM - 06164-PK2-010
BOTTOM END components
connecting rods
But any D-series 1.6L rods will work for upgrading.
Pistons
88-89 Integra OEM
There are many companies that offer ZC specific Pistons now, so Aftermarket is there.
Main & Rod bearings and thrust washer bearings
Piston Rings
88-91 Civic/CRX // 86-89 Integra
**Transmission quirks**
88 Transmissions are the only ones that are 21 splined
That means you must use a 88 ONLY clutch kit.
89-91 Transmissions are all 20 spline.
Old Nov 30, 2007 | 01:46 PM
Default Re: DOHC ZC Question!?! (djmesican)
Very informative thank you...what's your source of information if you don't mind me asking? This would have taken forever to find on your own.
Old Dec 3, 2007 | 05:00 AM
So for the Timing Belt, Water pump, and Gasket kit...I'm going to say it's for a 88-89 Integra?
Old Dec 3, 2007 | 05:10 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDaddy78155 &raquo;</TD></TR><TR><TD CLASS="quote">So for the Timing Belt, Water pump, and Gasket kit...I'm going to say it's for a 88-89 Integra? </TD></TR></TABLE>
Wow so the guy posted all the info and you didn't read anything at all?
Timing belt comes from a 88 Prelude Si 2.0 DOHC.
Gaskets are mainly 88-89 teg but some variances can occur.
Waterpump is the same as a 88-91 Civic/CRX D16.
Old Dec 3, 2007 | 06:12 AM
slammedz6ef's Avatar
get a 86-89 integra timing belt
Old Dec 3, 2007 | 07:10 AM
Andrew77's Avatar
Default Re: DOHC ZC Question!?! (slammedz6ef)
I too have a 90 crx si with a dohc zc, and just replaced all these parts. Used a 88 prelude si timing belt, a water pump for a 90 crx si, and got a whole gasket kit for an 89 integra. And everything worked out just perfectly.
Old Dec 3, 2007 | 07:27 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedz6ef &raquo;</TD></TR><TR><TD CLASS="quote">get a 86-89 integra timing belt</TD></TR></TABLE>won't work on JDM DOHC ZC
Old Dec 3, 2007 | 08:27 AM
DoHcZC91si's Avatar
Default Re: DOHC ZC Question!?! (Andrew77)
THEZCR.com Tried and True.
Old Dec 3, 2007 | 09:06 AM
wiZCo's Avatar
Stouts 'n' Scotch
NO!
The parts list above is correct and is reviewed time and time again. It comes from http://www.thezcr.com, the best ZC site out there.
Old Dec 3, 2007 | 09:34 AM
SIred91's Avatar
Rainman
NO. get it for the 88 prelude si.
Old Dec 3, 2007 | 10:27 AM
Loaded Butane's Avatar
Take the advice in your sig for giving out false info
Ahks
Feb 11, 2006 08:24 AM
andystart
Sep 17, 2004 05:32 AM
DOHC_EF
Aug 24, 2004 06:35 AM
JapJunkie
Apr 1, 2004 05:14 PM
SpeedMonkeyRacing
Jan 27, 2003 06:39 PM
