How to cut the pipes for a collector
Old Nov 30, 2007 | 11:53 AM
gorillam's Avatar
Default How to cut the pipes for a collector
How do I cut the 304L sch10 piping, do I use a vertical bandsaw or buy a small milling machine?
Just curious what is possible and maybe if someone has some jig/clamping ideas as I am trying to make my own sch10 longtube turbo manifold for my sr20.
Also how do you get that goldish finish on the 304L like fullrace and excessive have, I've only seen 304L as a dark brown finish?
I have tried searching how-ever i'l just appreciate someone with some experience with building manifolds to help me out.
Thanks,
Andrew
Old Nov 30, 2007 | 06:12 PM
manifoldmiketyson's Avatar
Default Re: How to cut the pipes for a collector (gorillam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gorillam &raquo;</TD></TR><TR><TD CLASS="quote">How do I cut the 304L sch10 piping, do I use a vertical bandsaw or buy a small milling machine?
Thanks,
Andrew</TD></TR></TABLE>
usually you rough cut with a band saw, chop saw or angle grinder, then finish with a mill or sander. jig's are dependent on the machine your using. depending on your collector length, spacing and inlet flange, you'll want a combination of a couple angles to get your rectangle for the flange. i think for a 4" its 10 degree and 14 degree. can't remember though. somthing close to that.
finish wise, you can polish or hit them with a wire brush. they will turn gold for a short amount of time before they change to brown. all end up brown. nothing you can do about it.
Old Jan 2, 2008 | 07:23 PM
socalismylife's Avatar
seems like a 14" cutoff saw would be the quickest way since it has a clamp and u can set mitre angles.
Old Jan 2, 2008 | 09:57 PM
k24em2's Avatar
Default Re: (socalismylife)
make sure you hold the pipe with your hand too when you cut....
seriously, we are beating a dead horse's skeleton with this thread
Old Jan 3, 2008 | 03:12 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you hold the pipe with your hand too when you cut..../sarcasm
seriously, we are beating a dead horse's skeleton with this thread</TD></TR></TABLE>
hahaha just in case someone thinks you're serious.
Old Jan 3, 2008 | 04:48 PM
DESTROYER's Avatar
I find it pointless to try an cut the collector to meet up as a rectangle. I use a bench vise and force it to be rectangle after it's put together.
Old Jan 3, 2008 | 05:39 PM
RC000E's Avatar
Default Re: (DESTROYER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DESTROYER &raquo;</TD></TR><TR><TD CLASS="quote">I find it pointless to try an cut the collector to meet up as a rectangle. I use a bench vise and force it to be rectangle after it's put together.</TD></TR></TABLE>
I thought of that but never tried it. I didn't want to risk marring up the collector from the jaws. I have semi soft jaws but....
Does it really work descent?
Old Jan 3, 2008 | 06:02 PM
boostedgsr1234's Avatar
not a bad idea i never thought of that when i was spending countless hours makeing a jig to make a fricken rectangle
ill try to post up some pics of my jig
Old Jan 4, 2008 | 09:04 AM
DESTROYER's Avatar
It does mar it, however, the weld covers up the damage if you place it in the vice properly.
Old Jan 4, 2008 | 02:55 PM
any photos?
Old Jan 5, 2008 | 05:51 PM
Lubo_25's Avatar
search google there should be some sort of online templates for printing out for cutting
Old Jan 5, 2008 | 06:45 PM
dbiker207's Avatar
both of these were square when i started. i used a vice to rectangle them.
140sx
Welding / Fabrication
Jan 2, 2008 07:17 PM
hatchinprogress
Dec 14, 2005 03:04 PM
OrangeBoost
10
Nov 17, 2005 01:53 PM
Bense
Jun 24, 2004 07:51 AM
