Swap ITR into 99 civic problem with ECU
Old Nov 30, 2007 | 10:45 AM
creepy116's Avatar
Default Swap ITR into 99 civic problem with ECU
hey im swapping a jdm itr into my civic and i was looking at the ecu's and i believe the p2p and the p73 ecu's have 1 different plugs from eachother, what do i need to do?
Old Nov 30, 2007 | 11:00 AM
BlueIntegraBoy's Avatar
Default Re: Swap ITR into 99 civic problem with ECU (creepy116)
You need an OBD2B ECU. You have an OBD2A ECU (P73) now.
Old Nov 30, 2007 | 11:06 AM
creepy116's Avatar
Default Re: Swap ITR into 99 civic problem with ECU (BlueIntegraBoy)
what about getting an obd2b to obd2a harness?
Old Nov 30, 2007 | 11:17 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 &raquo;</TD></TR><TR><TD CLASS="quote">what about getting an obd2b to obd2a harness?</TD></TR></TABLE>
Do you have emissions laws where yuou live that require a yearly emissions test where they plug up a scan tool and check for engine codes?
If so then you cannot pass emissions with a jumper harness and JDm P73 ECU because the JDM P73 ECU will not communicate with OBD2 scan tools at all. In fact, and I don't care what anyone says this is fact, the JDM P73 ECU has OBD2A plugs but in FACT runs an OBD1 program that only looks for one oxygen sensor, does not search for evap inputs, does not look for a CKF sensor, and does not throw codes for catalyst efficiency low codes.
If you have to pass BD2 scan emissions then you're in a really shitty position.
Ideally you could get a 00-01 Integra Type R P73 ECU, USDM, but they have that bullshit immobilizer key/igntion crap built in, so you cannot use them.
I guess we need to know if you need to pass an emissions test where they scan the codes...
JDM_Frijoles's Avatar
Or.....http://chicago.craigslist.org/....html gl.
Old Nov 30, 2007 | 11:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Swap ITR into 99 civic problem with ECU (JDM_Frijoles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles &raquo;</TD></TR><TR><TD CLASS="quote">Or.....http://chicago.craigslist.org/....html gl.</TD></TR></TABLE>
That won't help him because:
a. If it's a 97-98 ECu then it'll be exactly the same plug type that he already has
or
b. Even if the plugs match (00-01 type) it won't alllow his car to start due to the built in immobilizer crap
creepy116's Avatar
Default Re: Swap ITR into 99 civic problem with ECU (B18C5-EH2)
if doesnt matter if i need to pass in california im not trying to get bar ill pay when the time comes
Old Nov 30, 2007 | 11:24 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 &raquo;</TD></TR><TR><TD CLASS="quote">if doesnt matter if i need to pass in california im not trying to get bar ill pay when the time comes</TD></TR></TABLE>
Well if you don't care about it being legal then by all means buy a jumper harness that allows your JDM OBD2A P73 ECu to plug into your OBD2B car, and be done.
hondaman991
Mar 23, 2011 10:25 AM
B18C5-EH2
Jul 29, 2008 07:39 AM
turkdog
Nov 30, 2003 06:15 AM
Nameless RB26
Aug 27, 2002 05:07 PM
