my RPM gauge on cluster is on crack
Old Nov 30, 2007 | 12:08 AM
Fat Chick Magnet's Avatar
Default my RPM gauge on cluster is on crack
I just did a obd2a 96-97 SPEC ITR swap onto my obd2b 2000 GSR and everything is working fine until every time i hit vtec the rpm gauge on the cluster starts to spin clockwise & sometimes counter clockwise real fast and it happens every gear until i let off the gas and disengage out of vtec.
anyone got a clue on this one? is there a secret wiring/ground i have to mess with on the harness?
EDIT:
ground the blue wire on chassis harness near master cylinder to the distributor wire.
Modified by Fat Chick Magnet at 5:36 PM 12/20/2007
Old Nov 30, 2007 | 02:16 AM
Ill try to post a video tomorrow.
Old Nov 30, 2007 | 03:47 AM
JjuuN R's Avatar
Default Re: (Fat Chick Magnet)
LOL
Old Nov 30, 2007 | 04:18 AM
Ed 341's Avatar
Default Re: my RPM gauge on cluster is on crack (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">I just did a obd2a 96-97 SPEC ITR swap onto my obd2b 2000 GSR and everything is working fine until every time i hit vtec the rpm gauge on the cluster starts to spin clockwise real fast and it happens every gear until i let off the gas and disengage out of vtec.
anyone got a clue on this one? is there a secret wiring/ground i have to mess with on the harness? </TD></TR></TABLE>
A lot of non-ITR posts lately..
The needle goes around clockwise really fast because of the mad Vtack.
Either way it sounds like you are cuttting a lot of corners with your "B18C-R" swap(whatever that is). Take a step back and go over eveything...
Old Nov 30, 2007 | 05:20 AM
citrus3000psi's Avatar
Your description really isn't that helpful. Are you saying the RPM's jump? if so this can be related to tranny ground and the dizzy. I had issues with my distributor like this a while back. Search for some threads I started about it.
Old Nov 30, 2007 | 05:56 AM
Dave-ROR's Avatar
actually kinda common with the setup, do a search.
get RIGHT's Avatar
Default Re: my RPM gauge on cluster is on crack (Ed 341)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 &raquo;</TD></TR><TR><TD CLASS="quote">
Mad Vtack is usually the source of all my problems. I find harmonious Vtack to be the best.
Old Nov 30, 2007 | 06:43 AM
94rs-turbo's Avatar
https://honda-tech.com/zerothread?id=1836281
Old Nov 30, 2007 | 11:32 AM
OK i made a full out of myself, but ill post video later today.
Old Nov 30, 2007 | 01:57 PM
fourcsan's Avatar
* B A N N E D *
yeah its true...
did this whole problem start when you hit the ultimate MADD 3rd gear VTAKKyo? because thats what happened to me.
seriously im kidding. i had the same problem in my ITR with OBD2a jumper. it was my distributor first. my car wiring itself second. and my jumperharness from kingmotorsports third. check your wiring on the car itself. there are a few important grounds you should check that people with hella VTECHHHHH often slice up for the VTAK_AFC installs etc. also if you did a cluster swap recently. make sure its the right year.
Old Nov 30, 2007 | 02:18 PM
Default Re: (fourcsan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourcsan &raquo;</TD></TR><TR><TD CLASS="quote">yeah its true...
seriously im kidding. i had the same problem in my ITR with OBD2a jumper. it was my distributor first. my car wiring itself second. and my jumperharness from kingmotorsports third. check your wiring on the car itself. there are a few important grounds you should check that people with hella VTECHHHHH often slice up for the VTAK_AFC installs etc. also if you did a cluster swap recently. make sure its the right year.</TD></TR></TABLE>
my cluster is still the same one it came with original car, but i was planning on running the 96-97 JDM itr cluster within these few days, but I'm going to swap out distributors see if it helps.
Old Dec 1, 2007 | 11:48 AM
JDM_CRX_PLEASE's Avatar
thats tight. its because of the JDM vtec, your USDM integra cant take it and it just goes crazy!
ITR vtec is 100% better than GSR vtec
Old Dec 1, 2007 | 11:53 AM
Parada's Avatar
Default Re: (JDM_CRX_PLEASE)
check the flux capacitor, sounds like something might be going squirly in there.
Old Dec 2, 2007 | 04:56 PM
this video was taken on a closed freeway on-ramp so don't give me that bullshit comments on breaking the law.
here is my cluster on crack.
http://tinypic.com/player.php?v=732unhf&s=1
Old Dec 2, 2007 | 08:31 PM
USDMCIVICHATCH's Avatar
most likely the distributor. 00/01 distributors are different
Old Dec 2, 2007 | 08:41 PM
SuckMyDOHC's Avatar
Why do you always post in the ITR forum? This is for ITR CARS, not ITR swapped cars.
Old Dec 2, 2007 | 08:45 PM
Default Re: (SuckMyDOHC)
at least he wasn't asking about a single cam civic....
Old Dec 3, 2007 | 04:44 AM
Its either the cluster, rpm wire, dizzy, ground.
Old Dec 3, 2007 | 09:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">Why do you always post in the ITR forum? This is for ITR CARS, not ITR swapped cars.</TD></TR></TABLE>
You're right. I should of posted this on the Accord section.
Old Dec 3, 2007 | 09:41 AM
Default Re: (citrus3000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">Its either the cluster, rpm wire, dizzy, ground.</TD></TR></TABLE>
thanks, but i think problem is solved. It needs to be grounded from the distributor to the chassis harness.
Old Dec 3, 2007 | 01:08 PM
thanks, but i think problem is solved. It needs to be grounded from the distributor to the chassis harness. </TD></TR></TABLE>
What ground are you refering too? One of the pins on the harness? Or are you grounding the head/dizzy to the chassis?
Old Dec 3, 2007 | 03:57 PM
What ground are you refering too? One of the pins on the harness? Or are you grounding the head/dizzy to the chassis?</TD></TR></TABLE>
pins on harness i believe i have to still take it to my friends house ill keep you updated.
Old Dec 6, 2007 | 04:25 PM
so what was it?
Old Dec 9, 2007 | 11:34 PM
Default Re: (USDMCIVICHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">so what was it?</TD></TR></TABLE>
ground. ill take picture tomorrow and post it up FYI.
Old Dec 10, 2007 | 10:35 PM
fourcsan's Avatar
* B A N N E D *
was it the ground on the chassis ecu harness?
