TPS Code. Please help. Searched.
Old Nov 29, 2007 | 10:42 PM
aragorn1023's Avatar
Default TPS Code. Please help. Searched.
I have a 91' LX with a JDM D15B in it and it ran fine when i first did the swap, but after about a month later i started getting a roaming idle. Thinking it was the iacv I took it off and replaced it and then soon thereafter I got a cel 7 flashes, tps sensor. So i thought mayeb it was adjusted incorrectly...tried with no luck, reset ECU....no luck, and just got new tps and ......no luck. Extremely high idle at start around 3500-4000 then idles after warm up at minimum of 2250. Please help. Thanks.
P.s. I got my wiring done by rywire for the obd0 to obd1 so I will assume that they switched the outer two wires for the tps.
Old Nov 30, 2007 | 04:59 AM
alscrx's Avatar
Default Re: TPS Code. Please help. Searched. (aragorn1023)
Do you have a fast idle valve under the throttle body???
https://honda-tech.com/zerothread?id=1564019
Old Nov 30, 2007 | 05:35 AM
I'm not sure if the JDM D15B has that. I'll check today, but I am not entirely sure.
Old Nov 30, 2007 | 09:35 PM
Do you think the FITV could cause the ecu to throw a tps cel?
Old Nov 30, 2007 | 09:51 PM
danmdevries's Avatar
Default Re: (aragorn1023)
You didn't happen to have the TPS off at all did you?
You can always check to see the output voltage of the TPS. Take a multimeter, turn the ignition key to the run position, and insert your probes into I believe the outer two wires. Get a reading on the base/idle and then slowly open the throttle body, the voltage should increase linearly. I'm sorry I don't know the values off the top of my head. I have figures in my mind but I don't want to state them in case they are incorrect. I'm sure someone will chime in, otherwise they're available in the service manuals.
Old Nov 30, 2007 | 09:55 PM
Default Re: (danmdevries)
Yes I had it off, but not the new one since I have gotten it it went right on. ANd the voltages are .45-.5v at idle and 4.5-5v at Wot. It is calibrated, but I'm still getting a code. Thanks for the input though.
Old Nov 30, 2007 | 10:03 PM
alscrx's Avatar
wHAT ecu are you using??
What code number are you getting??
Give me actual number of flashes please
Modified by alscrx at 2:17 AM 12/1/2007
Old Dec 1, 2007 | 03:48 PM
Default Re: (alscrx)
Ecu is P08 and 7 short flashes
Old Dec 4, 2007 | 08:46 PM
Took it all apart today. Oil change and FITV off. Found that the plastic screw thing was ungodly loose. tightened it up and readjusted tps. No problems idle at 1k. Thanks everyone for your help. Timing is next. Thanks again I really appreciate it.
410ruga
Mar 25, 2014 12:07 AM
got00rice
Dec 30, 2009 12:16 PM
92ehatch
Nov 13, 2006 02:33 PM
mafay2
Jul 4, 2005 06:35 PM
