'90 accord block into '95
Ok my wife drove a '95 accord this past summer it was a reliable car for a good 9 years it ran low on oil and ended up spinning a rod and cracking a sleeve my friend has a block from his '90 accord and I was wondering if the block would bolt into the '95 I don't care if the vtec works or not, I want to know what parts I need to use head gasket,timing belt,mounts? I did a search but I'm not up to accord lingo all I work on are civics and integras accords and ludes are a whole diffrent world for me. thanks
The engine will bolt right up no special mounts required.
I'm going to assume that you have a 95 Accord EX with VTEC. If you are replacing it with an 90 Non VTEC F22A1 you may want to find a non VTEC ECU. If you don't your VTEC ECU will through a CEL. You may also want to keep all the OBD1 sensors and plugs from your current F22B1 and put them on the 1990 F22A1 (OBD0).
P0B is the ECU I belive you need? I could be wrong it is time to go to sleep.....the swap is not hard at all...and the lingo aint to different fro m civics and tegs...they are both cars with motors, oil, carpets...balah blah
