is my only option to weld a new flange
Old Nov 29, 2007 | 09:24 PM
Del Sol on Steroids's Avatar
Default is my only option to weld a new flange
is there a way to have a 4 bolt turbo on to a 5 bolt downpine?
Modified by Del Sol on Steroids at 2:06 AM 11/30/2007
Old Nov 29, 2007 | 10:07 PM
CoreyR's Avatar
Default Re: is my only option to weld a new flange (Del Sol on Steroids)
gotta weld a 4 bolt flange on.
Old Nov 29, 2007 | 10:15 PM
Default Re: is my only option to weld a new flange (CoreyR)
damn, just to be sure does garrett has a 4 bolt donwpipe?
Old Nov 29, 2007 | 10:16 PM
CoreyR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids &raquo;</TD></TR><TR><TD CLASS="quote">damn, just to be sure does garrett has a 4 bolt donwpipe?</TD></TR></TABLE>
i dont understand what youre asking
Old Nov 29, 2007 | 10:20 PM
precision turbos are mostly 5 bolt flanges, so is it garrett that has 4 bolts or 3bolts
Old Nov 30, 2007 | 08:15 AM
HiProfile's Avatar
Garrett turbos can come with 4-bolt outlets as well as 5-bolt outlets on their turbos. Off-the-shelf turbos just have the cheap or most common options, but you can order them in specific ways.
Old Nov 30, 2007 | 04:44 PM
JaredKaragen's Avatar
If I am not mistaken, 3 of the 4 holes are there in a 5 bolt flange, I don't see wht you can't get a 4 bolt gasket, drill the 4th hole, then trim the 5 bolt flange if it don't fit.
now, your DP might be pointed in the wrong direction after......
Old Nov 30, 2007 | 06:59 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids &raquo;</TD></TR><TR><TD CLASS="quote">precision turbos are mostly 5 bolt flanges, so is it garrett that has 4 bolts or 3bolts</TD></TR></TABLE>
Not necessarily as they offer both. 2 holes only line up... the 3rd one is close but is about 1/8-1/4" off. The orientation will most likely be different as well.
5 bolt
4 bolt
Reweld the flange and make it easy on yourself.
Old Nov 30, 2007 | 10:55 PM
mike93eh2's Avatar
i bought my precision turbo with 4 bolt because it was cheaper than the 5 bolt.
and i dont think there is such a thing as a 4 bolt gasket. ive never used gaskets. they wont leak at all if both surfaces are flat.
Old Nov 30, 2007 | 11:01 PM
bigbadboy's Avatar
i got a 4 bolt gasket from ATP works well.
Old Dec 1, 2007 | 12:45 PM
Default Re: is my only option to weld a new flange (HiProfile)
iight then. thanks everyone
Old Dec 1, 2007 | 11:06 PM
just gonna wait until i can find a 5 bolt
Old Dec 3, 2007 | 08:26 AM
Default Re: is my only option to weld a new flange (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
4 bolts and 5 bolts are the same in price. I know because I distribute for precision.
Old Dec 3, 2007 | 08:34 AM
mike93eh2's Avatar
Default Re: is my only option to weld a new flange (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
4 bolts and 5 bolts are the same in price. I know because I distribute for precision.</TD></TR></TABLE>
could of sworn they were more.... at least where i bought mine..
but i guess its just garrett that charges $50-100 more for 5bolt instead of 4bolt.... WHY? i dont know...
Old Dec 3, 2007 | 08:39 AM
Precision uses garrett CHRA's.... not covers. It could just be what the place you bought it from was telling you because they wanted to sell you the 4 bolt instead of the 5 bolt, lol.
Old Dec 3, 2007 | 08:47 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Precision uses garrett CHRA's.... not covers. It could just be what the place you bought it from was telling you because they wanted to sell you the 4 bolt instead of the 5 bolt, lol.</TD></TR></TABLE>
yea, i know.. but garrett does charge more..
anyone know why?
http://rcautoworks.com/index.p...tId=5
http://www.rogueusa.com/Garret...7.htm
Old Dec 3, 2007 | 09:06 AM
Dunc's Avatar
BCICAN
Just weld a v-band flange to the turbos exhaust housing. That will be much better than any 4 or 5 bolt flange. You'll never have to worry about bolts again.
Old Dec 3, 2007 | 11:09 PM
Default Re: is my only option to weld a new flange (Dunc)
good idea, but i'll just wait until i see a good used 5 bolt, could use those $200
Old Dec 4, 2007 | 12:41 PM
TheShodan's Avatar
Moderator
but i guess its just garrett that charges $50-100 more for 5bolt instead of 4bolt.... WHY? i dont know...</TD></TR></TABLE>
Different grade of steel in the 5 bolt housings than the 4 bolts FROM GARRETT. There's a bit more nickel in them than the T31 4 bolt. Not enough to really Matter IMHO, because 4 bolts are easier to install, but that's how they work.
Since Precision uses the same material in both their 4 bolt and 5 bolt from the foundery they use, there's no difference in price. It's an absorbed cost in their manufacturing either way.
Old Dec 4, 2007 | 12:45 PM
CoreyR's Avatar
Default Re: is my only option to weld a new flange (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
Since Precision uses the same material in both their 4 bolt and 5 bolt from the foundery they use, there's no difference in price. It's an absorbed cost in their manufacturing either way.</TD></TR></TABLE>
so thats why the 5 bolt is more, thanks for the info ive been wondering.
civic-r11
Mar 23, 2011 09:09 AM
Hump-Free
Oct 9, 2006 08:54 PM
Lilkong
Dec 18, 2004 07:46 AM
DMF
Sep 16, 2003 10:17 AM
kenbdSi
Oct 27, 2002 10:03 AM
