ls/vtec
i got a ls bottom end. does any1 kno which head i use. i thought it depened on if the block was obd1 or 2. so if i use a obd2 block, a obd1 b16 will mesh and all i need is a obd1 wiring harness. help me out
u can use any b-series vtec head for a ls/v, and judging by ur display name you should u use ur factory obd1 engine harness as it will have the vtec wire already intergraded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch</TD></TR></TABLE>
Even better, go here. Its in all-motor, a few links down from here......
https://honda-tech.com/zerothread/1676914
It will tell you damn near everything you have to do/choices you can make.
natedogsuperman
May 10, 2017 06:21 PM
