b series cable clutch in a hydro tranny??
Old Nov 29, 2007 | 08:19 PM
sloweredcivic's Avatar
Default b series cable clutch in a hydro tranny??
hey sorry if this is common knowledge tried to search no luck, i was wondering if i could use my act clutch out of my xsi swap in a b20, 2000 si tranny combo?? since it only has 10xxx miles on it i want to reuse it, thanks andy
Old Nov 30, 2007 | 05:10 AM
StorminMatt's Avatar
Default Re: b series cable clutch in a hydro tranny?? (sloweredcivic)
You can only reuse the pressure plate. The newer disk has a larger spline, so your old one won't work. Also, the release bearing won't work. And finally, you don't want to reuse a pilot bearing.
Old Nov 30, 2007 | 05:14 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: b series cable clutch in a hydro tranny?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">You can only reuse the pressure plate. The newer disk has a larger spline, so your old one won't work. Also, the release bearing won't work. And finally, you don't want to reuse a pilot bearing.</TD></TR></TABLE>
x2, you can probably get just a new disc if you call ACT for a hydro.
Old Nov 30, 2007 | 05:15 AM
ludesrv's Avatar
It will work just fine. I used a flywheel/clutch from a 2000 SI into my B16A with YS1 swap. Worked awesome. Then I had it on my LS. It's all the same stuff.
Old Nov 30, 2007 | 05:31 AM
ComeOnKip's Avatar
ys1 = not like many other cable trans. exedy has 2 different part numbers for them. 90% of cables you see are not compatible. most cables have the 25mm shaft, not the 26mm.
Old Nov 30, 2007 | 05:32 AM
IT GUY's Avatar
Default Re: (ludesrv)
90-91 cable transmissions use a different clutch.
the hydro and 92-93 ys1 clutches are the same.
i<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">It will work just fine. I used a flywheel/clutch from a 2000 SI into my B16A with YS1 swap. Worked awesome. Then I had it on my LS. It's all the same stuff.</TD></TR></TABLE>
key words.
Old Nov 30, 2007 | 05:35 AM
ludesrv's Avatar
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">90-91 cable transmissions use a different clutch.
i
key words.</TD></TR></TABLE>
He said he has an XSi swap, those are Y1 equipped IIRC, my tranny is a Y1 casing with YS1 gearing.
Old Nov 30, 2007 | 05:39 AM
ComeOnKip's Avatar
hmmm I thought y1/s1 were all the same input shafts.....
Old Nov 30, 2007 | 05:43 AM
my tranny was a ys1 w/lsd out of an obd1 xsi
Old Nov 30, 2007 | 05:46 AM
ComeOnKip's Avatar
homerun. your clutch will work.
IT GUY's Avatar
Default Re: (ComeOnKip)
honda/acura part numbers
1990 integra clutch:
22200-PR4-020 DISK, FRICTION 1 1990 INTEGRA
22300-PR4-020 DISK, PRESSURE 1 1990 INTEGRA
1995 integra clutch:
22200-P72-015 DISK COMP., FRICTION 1 1994 INTEGRA
22300-P54-010 DISK, PRESSURE 1 1994 INTEGRA
1992 integra clutch:
22200-P72-015 DISK COMP., FRICTION 1 1992 INTEGRA
22300-P54-010 DISK, PRESSURE 1 1992 INTEGRA
Kip, I dig that avatar. I still have a "milo goes to college" ratty t-shirt from 15 years ago.. lol
Old Nov 30, 2007 | 06:20 AM
ComeOnKip's Avatar
descendents roxzors. I wish I got a chance to see them when they still toured, but i saw the next best thing a bunch of times (all).
fbw2003
Jul 26, 2006 07:52 PM
MniMeHatch89
Jun 12, 2006 04:45 PM
teggrl
May 25, 2006 02:19 PM
Beau Gotti
Feb 27, 2006 09:40 PM
EL Vap133
Jan 5, 2004 08:29 AM
