Car won't go into gear- need confirmation
Old Nov 29, 2007 | 07:00 PM
Lewd Nate's Avatar
Default Car won't go into gear- need confirmation
I have a manual transmission and I can't put it into gear. I checked and the clutch cylinder is empty. I'm pretty sure that's my problem, but I don't really know much about hydraulic clutches, all my cars have been cable. Anyway if someone can confirm that's what needs to be done, that be great.
Also, when I bleed the clutch fluid, will I lose some of that slop, or do I still need to adjust the pedal?
Old Nov 29, 2007 | 07:01 PM
xxmastermindxx's Avatar
Default Re: Car won't go into gear- need confirmation (Lewd Nate)
you probably have a leak if all your fluid is gone... you can check your master cylinder, feel around the drivers side carpeting area, around the firewall, for signs of leakage. that'd be the first step.
Old Nov 30, 2007 | 07:34 AM
flyrod's Avatar
adding fluid and bleeding the clutch will fix the immediate problem, but you probably have a leak somewhere.
Old Nov 30, 2007 | 08:28 AM
mrrhode04's Avatar
Yeah if you have no fluild in the system it won't work, it works like the break system you need something to compress air is not enough.
Old Nov 30, 2007 | 09:28 AM
Acidcrakker's Avatar
Default Re: Car won't go into gear- need confirmation (mrrhode04)
Anyone have pictures of what a hydrolic clutch looks like. I would really like to see.
Old Nov 30, 2007 | 10:09 AM
ECX's Avatar
ECX
* B A N N E D *
Fluids cannot be compressed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrrhode04 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah if you have no fluild in the system it won't work, it works like the break system you need something to compress air is not enough.</TD></TR></TABLE>
Check your slave cylinder, but it really is sounding like your master cylinder. Have fun changing it, it's a pain in the ***.
Old Nov 30, 2007 | 01:40 PM
darkspector2.0's Avatar
It's not THAT bad
Old Nov 30, 2007 | 01:42 PM
dagle's Avatar
Default Re: (darkspector2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have pictures of what a hydrolic clutch looks like. I would really like to see. </TD></TR></TABLE>
you have a hydrolic clutch system. hydrolic means fluid, master cylinder and brake cylinder control the clutch pedal and the brake pedal respectively.
JDMgareth
Jan 21, 2008 03:36 PM
importfever96
Jul 29, 2005 10:04 AM
vti444
Jun 13, 2005 03:44 PM
KW2000
Jan 16, 2004 11:05 PM
VTechie
Jul 12, 2002 04:09 AM
