fuel pump not turning on please read
Old Nov 29, 2007 | 06:04 PM
jaydmtim's Avatar
Default fuel pump not turning on please read
I just pulled my dash out of the civic, its a 92 cx hatch. I dyed it and put it back in. Once everything is back together, the fuel pump is not even coming on. I put a relay that I know works on, and still nothing. I used a test light, and none of the pins in the connector are showing any power. Anyone heard of this happening after pulling out a dash. the harness that wraps around to the guage cluster, radio, etc and the one on the passenger side shouldnt have anyhting to do with the fuel pump right??? Some one please help asap. All my guages work, and it will turn over, but the pressure guage is pegged out a 0psi.
Old Nov 29, 2007 | 06:13 PM
Civic92Turbo's Avatar
Default Re: fuel pump not turning on please read (jaydmtim)
ground??? I think the dash has two grounds, one for the radio harness and one close to the fuel relay. if that's not it open up your fuel relay and check the solder connections to see if they points are not broken
Old Nov 29, 2007 | 06:26 PM
jaydmtim's Avatar
I got the one behind the gauge cluster, where is the other one. The relay is not getting power....I am stumped for the first time since I got the car and did a swap or two
Old Nov 29, 2007 | 06:48 PM
stock_honda_coupe's Avatar
Default Re: (jaydmtim)
Get a wirring diagram and start checking for power at the pump, working your way back through the harness till you find out where the power stops.
Old Nov 29, 2007 | 06:53 PM
jaydmtim's Avatar
anyone know where I can find a wiring diagram, I traced it back to where the relay, I cant trace it any further. Please help me find a diagram.
Old Nov 29, 2007 | 07:26 PM
jaydmtim's Avatar
anyone else want to chime in
Old Nov 29, 2007 | 07:51 PM
ShaggyZ6's Avatar
diagram 1
http://arrc.epnet.com/autoasp/...8.pdf
diagram 2
http://arrc.epnet.com/autoasp/...9.pdf
ef'dup
May 18, 2012 04:09 PM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
quickv8s10
Sep 27, 2007 08:19 PM
usdmblackcivic
Sep 25, 2007 06:19 PM
