just converted from auto to manual, ECU swap?
i have just successfully swapped my 92' lude from an auto trans to manual, along with a fidanza clutch and light flywheel, everything worked great so far, (btw i took pics throughout to make a good write-up for trans conversion) but i am kinda lost on the whole ECU part of this, its an obd1 computer and all i did was i "fooled" the car to thinking it is in neutral all the time, so i can get my key out and start/stop the engine. the car drives ok, ive only taken it around the driveway so far, but it mechanically drives and idles properly but someone told me that the automatic computer makes fuel and other adjustments according to pre-set "shift times"
my question is should i get a 92 prelude MANUAL computer?
and if so what is the code for the computer i need?
any other computers that could work?
thanks guys
thanks guys
