Will a 9006 Bulb, fit in a 9007 spot?
Old Nov 29, 2007 | 05:05 PM
standbackimapro's Avatar
Default Will a 9006 Bulb, fit in a 9007 spot?
friend of mines srt4 takes a 9007 bulb, and i got a 9006 hid kit, the notches that twist into the headlight housing look the same, the only difference i can see is that the 9006 has the plug that angles off, and the 9007 is straight
Old Nov 29, 2007 | 06:30 PM
95 integra's Avatar
Default Re: Will a 9006 Bulb, fit in a 9007 spot? (standbackimapro)
9006 is a high beam bulb and should not be used in the low beam spot....you can shave the notches down and make them fit though.
Old Nov 29, 2007 | 07:57 PM
GSR in progress 96's Avatar
* B A N N E D *
I thought 9006 was low and 9005 was high?
Old Nov 29, 2007 | 09:40 PM
PACT man's Avatar
Default Re: (GSR in progress 96)
^^^I do believe you are correct. As for the OP, why don't you just pop the bulbs out and try real quick, it doesn't take a genius to change a light bulb(how many people it takes is up to you though).
Old Nov 30, 2007 | 05:46 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (PACT man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">9006 is a high beam bulb and should not be used in the low beam spot....you can shave the notches down and make them fit though. </TD></TR></TABLE>
did you fat finger that one?
9005 is high beam
9006 is low beam
9006 and 9007 are NOT interchangeable
jweezy225
Aug 9, 2004 05:43 PM
Zulu888
Oct 2, 2003 08:58 PM
shipsaeki
May 9, 2003 03:56 PM
Hella Clean
Jul 15, 2002 06:28 AM
mugenracer
Mar 24, 2002 02:08 AM
