Crappy Ebay SS brake lines.
Old Nov 29, 2007 | 04:22 PM
TwoKSiR's Avatar
Default Crappy Ebay SS brake lines.
I bought a set of the ebay ss brake lines after a couple friends ran them and had no problems and were very happy with them. I get them on and go to bleed the brake system and find a damn hold in one of the lines. You cant see the hole if you look but as the pic shows you can see fluid spraying out of it. There one other small hole it come out of if you hold your finger tight over the main hole. Is it common for this to happen? Has anyone ever seen it before. The company is sending me a new set of lines so if anyone just needs one or two lines let me know.
Old Nov 29, 2007 | 07:32 PM
onepoint6i's Avatar
Default Re: Crappy Ebay SS brake lines. (TwoKSiR)
edit...never seen that before
Old Nov 29, 2007 | 08:22 PM
Padawan's Avatar
Darth ModerVader
I think the lesson here is not to try cutting costs when it comes to a safety item as important as the brake system.
Regardless of whether the seller is sending you a replacement, I wouldn't run those on my car.
Old Nov 29, 2007 | 08:24 PM
onepoint6i's Avatar
Default Re: Crappy Ebay SS brake lines. (Padawan)
agreed...earls is the way to go
Old Nov 30, 2007 | 11:54 AM
Under_Pressure's Avatar
Default Re: Crappy Ebay SS brake lines. (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I think the lesson here is not to try cutting costs when it comes to a safety item as important as the brake system.
Regardless of whether the seller is sending you a replacement, I wouldn't run those on my car. </TD></TR></TABLE>
QFT
Old Nov 30, 2007 | 12:13 PM
CerealKiller's Avatar
ebay for brake lines =
Old Nov 30, 2007 | 12:22 PM
TwoKSiR's Avatar
Default Re: Crappy Ebay SS brake lines. (Under_Pressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under_Pressure &raquo;</TD></TR><TR><TD CLASS="quote">
QFT</TD></TR></TABLE>
QFT? Like I said I said the same thing but alot of people told me that they had good luck with them. A buddy ran them on his 680 whp hatch with no issues. Everyone I have heard of had good luck. THey are made my a company called Gforce Brakes.
Old Nov 30, 2007 | 02:50 PM
mattssi's Avatar
If your replacement lines have a similar defect and they start to leak fluid while your driving, it could cause a fire and loss of your ability to brake. I would be unable to install those on my car after having that kind of issue. that could be something that is deadly....
Old Dec 1, 2007 | 09:58 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR &raquo;</TD></TR><TR><TD CLASS="quote">QFT? Like I said I said the same thing but alot of people told me that they had good luck with them. A buddy ran them on his 680 whp hatch with no issues. Everyone I have heard of had good luck. THey are made my a company called Gforce Brakes.</TD></TR></TABLE>
"Good luck" is not something I'd want to associate with brake lines, and the horsepower output of a vehicle is irrelevant to the discussion. You've already witnessed a severe defect in one of these lines, that could have resulted in a catastrophic accident. If that's not enough of a reason to opt against installing and using them, I don't know what would be.
Old Dec 1, 2007 | 12:24 PM
peter.blais's Avatar
Absolutely- your brake lines hold your life in their little veins...
Aeroquip or earls ONLY!
Next time you think about cheaping out on brake lines, think about this:
http://www.youtube.com/watch?v=gOhcnXFAGF4
PS: any true DOT approved brake line assembly is supposed to be pressure tested before use, and thats a DAMN good policy. Second, those guys above are lucky to be alive.
Old Dec 1, 2007 | 07:45 PM
Muckman's Avatar
Moderator in Chief
Default Re: Crappy Ebay SS brake lines. (peter.blais)
Theres no way his lines are DOT certified. And if the vendor is claiming they are then Id ask him to prove it. I bet they say for "off road use only", read "dont sue us when they leak and cause certain death".
itellyawhat
17
Nov 27, 2007 10:44 PM
Miracle
Suspension & Brakes
14
Nov 6, 2006 11:04 AM
kornerk12
Dec 19, 2005 06:08 AM
HT Chaplain
Dec 31, 2003 02:34 PM
Chugger
Feb 27, 2003 03:51 PM
