Clutch... One picture to name that Part!!
Old Nov 29, 2007 | 02:09 PM
0hboitony's Avatar
Default Clutch... One picture to name that Part!!
Its killing my carpet cause it drips down and makes it black! I dunno whats the part called and any info when I can fix it???? Please... ABout to sale my car and need it fixed asap! Thank you honda tech!
Old Nov 29, 2007 | 02:29 PM
SoTexDC2's Avatar
Default Re: Clutch... One picture to name that Part!! (0hboitony)
I believe that is the Clutch Master cylinder.
Old Nov 29, 2007 | 02:43 PM
thewrai6th's Avatar
Default Re: Clutch... One picture to name that Part!! (SoTexDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoTexDC2 &raquo;</TD></TR><TR><TD CLASS="quote">I believe that is the Clutch Master cylinder.</TD></TR></TABLE>
That is correct, and you need a new one if it leaks. I got mine from ebay for cheap, genuine Acura part...
http://cgi.ebay.com/ebaymotors...94273
Here is one, it's easy to replace, you just need some brake fluid and a small hose to bleed the slave cylinder. There is some easy adjustment involved, get your manual from hondahookup.com if needed.
Old Nov 29, 2007 | 02:55 PM
AWD Terror's Avatar
Old Nov 29, 2007 | 03:15 PM
0hboitony's Avatar
Default Re: Clutch... One picture to name that Part!! (thewrai6th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thewrai6th &raquo;</TD></TR><TR><TD CLASS="quote">
Here is one, it's easy to replace, you just need some brake fluid and a small hose to bleed the slave cylinder. There is some easy adjustment involved, get your manual from hondahookup.com if needed.</TD></TR></TABLE>
THank you so much man!
Old Nov 29, 2007 | 04:01 PM
integraRS-T's Avatar
yeah autozone or a.autoparts $40-60
MelloYelloCRX
Sep 6, 2007 02:32 PM
93H22Vtec
Jan 20, 2007 08:41 AM
hip_hop_s0ulchild
Oct 22, 2005 01:35 PM
nubs
Dec 16, 2004 03:28 AM
