dohc zc problem
Old Nov 29, 2007 | 01:49 PM
1kleenef's Avatar
Default dohc zc problem
i have a dohc zc that i just adjusted the valves on yesterday. Now this morning it wont start. After me and a friend finished the adjustment it wouldnt stay running like it would start but then die right away so the guy helping me messed with the throttle body a lil bit and had it running decent a little high idle but nothing major. So i get up this morning and nothing, just cranking with foot to the floor anyway that i tried it still was nothing. So i come home from work and work on it and wondering if there is a way to adjust the little thing that pushes on the throttle body wheel or whatever its run off a vacuum to the intake manifold. If u have a zc u will understand wat im talking about. ne help would be greatly appreciated. Thanks and sorry for the novel here.
Old Nov 29, 2007 | 01:54 PM
SIred91's Avatar
Rainman
Default Re: dohc zc problem (1kleenef)
If it was running BEFORE you guys messed with the valves then you did something wrong.
Old Nov 29, 2007 | 02:00 PM
1kleenef's Avatar
Default Re: dohc zc problem (SIred91)
like.........
i just know that we had it running last night so i dont know y it is acting up now except for maybe that thing that pushes on the throttle body pulley thing
Old Nov 29, 2007 | 03:11 PM
24TEN's Avatar
PHANTOM MENACE
Can you verify what the valve lash was adjusted to? My honest guess is that they are overtightened and your valves aren't closing, resulting in no compression.
Old Nov 29, 2007 | 03:23 PM
1kleenef's Avatar
Default Re: dohc zc problem (24TEN)
well i have it running now and i dont have neway to check the lash but if i didnt have any compression would it run at all i mean it kinda sounds a little rough but still runable
Old Nov 29, 2007 | 03:35 PM
24TEN's Avatar
PHANTOM MENACE
Depends on how many cylinders don't have compression. Now you just said that you don't have any way to check the lash, I have to ask, how was it checked when you and your friend did it the first time around?
Old Nov 29, 2007 | 03:43 PM
1kleenef's Avatar
we kinda did a ghetto by ear job but has always worked before idk its running now i guess ill just see how it runs for a while or get a gauge sometime does anyone kno wat the clearances are for a dohc zc intake and exhaust
Old Nov 29, 2007 | 03:50 PM
24TEN's Avatar
PHANTOM MENACE
My guess is that maybe a one or two valves may not be fully closing. After I've adjusted my valves on a motor, I usually spin the motor (the correct direction of course) then check and make sure the amount of play is uniform. There have been times that I've adjusted it to the exact spec needed, but afterwards when I double check there is 0 clearance and I have to do it again. If there is 0 clearance, then there's a strong possibility that the rocker arm (or whatever you might call it) is already pushing the valve open.
Old Nov 29, 2007 | 03:54 PM
1kleenef's Avatar
does any one know wat the correct clearances for a dohc zc are then?
Old Nov 29, 2007 | 03:59 PM
hailchristian's Avatar
http://www.thezcr.com/forums/s...10057
its all in there.
24TEN's Avatar
PHANTOM MENACE
It's been a while since I've done mine, but I'm sure I went with whatever an 89 Integra spec is. I'm almost positive that most Honda's are (or around) .007-.009 for intake and .009-.011 for exhaust. Don't quote me on that just yet though. Search.
EDIT:
According to:
.005 intake, .006 exhaust
Old Nov 29, 2007 | 04:17 PM
Fuzzy Rhubarb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">.005 intake, .006 exhaust</TD></TR></TABLE>
I did that on my d15. It runs great too.
A dohc zc might be similar but: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">Don't quote me on that just yet though. Search.</TD></TR></TABLE>
Old Nov 29, 2007 | 05:01 PM
jlicrx's Avatar
DOHC ZC valve clearance:
Intake - 0.13mm - 0.17mm - 0.005 in. - 0.007 in.
Exhaust - 0.15mm - 0.19mm - 0.006 in. - 0.008 in.
on the DOHC ZC, you check the clearance between the top of the rocker arm and the bottom side of the cam lobe - not between rocker and valve like you would a SOHC
Old Nov 29, 2007 | 06:04 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">I have to ask, how was it checked when you and your friend did it the first time around?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1kleenef &raquo;</TD></TR><TR><TD CLASS="quote">we kinda did a ghetto by ear job but has always worked before</TD></TR></TABLE>
LO-*******-L.
Old Nov 29, 2007 | 06:21 PM
1kleenef's Avatar
Default Re: dohc zc problem (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
LO-*******-L.</TD></TR></TABLE>
thanks tippyman i know that wasnt the most intelligent decision these two minds have made. haha
909ej195
Jan 19, 2007 06:29 AM
Crx-Racer4Life
Oct 31, 2006 06:36 PM
sleeperx
Aug 11, 2003 09:42 AM
