valve calibration
wath are the recomenden valves calibration of the skunk 2 stage 2 cams, and the set of the camgears???? please help, i know it come in the box but i had lost that paper.
Valve Lash Skunk2 Stage 2 = .007" intake and .008" exhaust
As for camgear settings DEGREE YOUR CAMS.
p.s. You can use +4 degrees intake and +4 degrees exhaust as a starting point, but I highly recommend checking all your clearances prior to using these settings and firing off the engine. Degreeing your camshafts is the correct way to get your optimal camgear settings.
Raptastik87
Sep 30, 2007 05:05 PM
fdjizm
Sep 30, 2006 05:44 PM
