codes 9 and 19?
my 92 hatch with a stock motor is throwing CEL codes 19 which is 19 Automatic transmission lockup control valve and code 9 that really confused me which is cylinder sensor... i have had the code 19 before and it was because of an automatic ecu... but this code just now showed up after i have owned the car for about 6 months.. help please?
the cylinder position sensor is in the dizzy. does the car run rough or anything like that. see if a friend or somebody will let you switch dizzy's with them. if the code goes away then you need a new dizzy, if it comes back well you got some searching to do
seanyboy
Aug 27, 2007 12:24 PM
