RSX or EP brakes on a EK??
did i hear this right ??
can you use the rsx or EP brake assemble on a EK like if i wanted to do a 5lug conversion ?? what all would be involved ? is it difficult ?
the rsx front brake setup will work on your ek with the type s rotors redrilled and calipers brackets milled .060 for an 11.8" setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">You can however, use 02-03 EP3 or base RSX rear calipers and rotors on a 96-00 with rear discs.</TD></TR></TABLE>
stock integra/ civic rear disc brakes use a 9.4" rear rotor; the ep3/rsx rear calipers upgrade to 10.2" rotor.
https://honda-tech.com/zerothread?id=1090780
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">the rsx front brake setup will work on your ek with the type s rotors redrilled and calipers brackets milled .060 for an 11.8" setup</TD></TR></TABLE>
* *pm BrakeExpert, he mills brackets, re-drills rotors & specializes in OEM honda brake upgrades
S2000 front brake upgrade for EX Civics and Integras
https://honda-tech.com/zerothread?id=2060223
How to put X brakes on your 96-00 EK Civic (revised) Upgrade Chart - UPDATED
https://honda-tech.com/zerothread?id=1811368
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Nope you can't.
80 dolla crx hf
Suspension & Brakes
May 9, 2010 11:36 AM
JCracer723
Dec 2, 2006 12:06 AM
