WILL I NEED TO CHANGE MY ROTORS IN MY STD 91 HATCH FOR B SERIES SWAP???
Old Nov 29, 2007 | 11:03 AM
NATEDEEZY's Avatar
Default WILL I NEED TO CHANGE MY ROTORS IN MY STD 91 HATCH FOR B SERIES SWAP???
I WANT TO KNOW WHEN SWAPING A LS IN MY 91 STD HATCH DO I HAVE TO CHANGE THE ROTORS BECAUSE B SERIES AXLES HAVE BIGGER DIAMETER INPUT SHAFTS RIGHT?????
Old Nov 29, 2007 | 11:05 AM
SIred91's Avatar
Rainman
Default Re: WILL I NEED TO CHANGE MY ROTORS IN MY STD 91 HATCH FOR B SERIES SWAP??? (NATEDEEZY)
STOP YELLING!!
Old Nov 29, 2007 | 11:11 AM
JustAnotherRex's Avatar
Default Re: WILL I NEED TO CHANGE MY ROTORS IN MY STD 91 HATCH FOR B SERIES SWAP??? (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">STOP YELLING!!</TD></TR></TABLE>
BUT THE KEYS WONT LET ME THEY JUST KEEP ON GOING
Old Nov 29, 2007 | 11:12 AM
CRX Toad's Avatar
Default Re: WILL I NEED TO CHANGE MY ROTORS IN MY STD 91 HATCH FOR B SERIES SWAP??? (JustAnotherRex)
https://honda-tech.com/zerothread/1508680 please see the FAQ
Did you change the knuckles? Can you give us more info? Specifics? We got a ton of these threads a week we are not mind readers. Also PLEASE stop typing in all caps.
Caps make us very irritable and makes us crazier.
Old Nov 29, 2007 | 11:18 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: WILL I NEED TO CHANGE MY ROTORS IN MY STD 91 HATCH FOR B SERIES SWAP??? (CRX Toad)
Old Nov 29, 2007 | 11:33 AM
NATEDEEZY's Avatar
well i type in all caps so i didnt know i was yelling...lol... but i have not changed anything yet ive done swaps before when i worked at qwiken motorsports in so cal but never one like this......
1991 ef hatch (std)
completey stock want to put a b series in in know i will need
motormounts
shortend shift linkage
axles halfshaft
ecu w/ obdo to obd1 harness
and wire my car from dpfi to mpfi
but didnt know if i needed to change rotors or anything else like that so thats why i asked ......thanks for the responses
Old Nov 29, 2007 | 11:51 AM
SIred91's Avatar
Rainman
Default Re: (NATEDEEZY)
You are on the right track.....rotors will be fine.
Old Nov 29, 2007 | 11:58 AM
NATEDEEZY's Avatar
or should i just get the si knuckles???
Old Nov 29, 2007 | 12:05 PM
alscrx's Avatar
Are you sure if your asking the right question??
You mean you want to know if you need to swap out your hubs/spindles because the std hub is smaller than b series axles?
Use si or dx hubs
HF and STD are different
Old Nov 29, 2007 | 12:11 PM
SIred91's Avatar
Rainman
Default Re: (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure if your asking the right question??
Use si or dx hubs
HF and STD are different</TD></TR></TABLE>
Old Nov 29, 2007 | 01:44 PM
NATEDEEZY's Avatar
thank you for the answer ....maybe i wasnt asking the right question.........std hatchbacks are gay......i had an 89 si hatchback before and it wasnt nearly as much of a headache....lol
BrandonM5400
Mar 28, 2012 01:21 PM
6SPD_EK
Nov 7, 2006 01:39 PM
CIVICLUDE
34
Jul 10, 2005 03:43 PM
Crx2092
Nov 7, 2004 04:31 PM
