clutch engagement
5th genhere...I have been noticing my clutch engagement is higher than it used to be and was wanted to know how I would adjust the engagement to be a little lower?
Thanks guys
Thanks guys
Look on the top back side of your clutch pedal, there's a threaded bolt that goes through the firewall, and attaches to the back of the pedal. Loosen the 12mm nut, adjust the bolt to your desired feel, then tighten the bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubzz24 »</TD></TR><TR><TD CLASS="quote">Look on the top back side of your clutch pedal, there's a threaded bolt that goes through the firewall, and attaches to the back of the pedal. Loosen the 12mm nut, adjust the bolt to your desired feel, then tighten the bolt.
Just remember to tighten that jam nut real good so the rod bolt on the master cylinder doesn't come loose over time.
Steven.
Mid-Atlantic (Sales)
May 25, 2008 06:53 AM
tyrub42
Jul 26, 2006 10:15 PM
Pee Wee
10
Apr 23, 2006 11:11 AM
