clutch
Old Nov 29, 2007 | 09:10 AM
globy123's Avatar
Default clutch
Hi. IF you disengage the clutch while you still have your foot on the gas, would that wear the clutch faster or damage it?
Old Nov 29, 2007 | 09:29 AM
p nut's Avatar
Yes.
Old Nov 29, 2007 | 10:52 AM
globy123's Avatar
Default Re: (p nut)
Can you be more specific. I'm not sure how the clutch works. Why would it damage the clutch?
Old Nov 29, 2007 | 10:54 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (globy123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by globy123 &raquo;</TD></TR><TR><TD CLASS="quote">Can you be more specific. I'm not sure how the clutch works. Why would it damage the clutch?</TD></TR></TABLE>
Because the flywheel is still spinning very fast when you disengage the clutch. Wears the surface more quickly.
http://auto.howstuffworks.com/clutch.htm
Old Nov 29, 2007 | 11:11 AM
tpr's Avatar
tpr
Default Re: clutch (globy123)
I disagree. The only detrimental issue is the sudden no load condition on the motor. But it should not damage the clutch unless you hold it a just partially disengagged and let it slip (can you say heat buildup) but not completely release the clutch.
Old Nov 29, 2007 | 11:21 AM
Ek Forever y0!
Default Re: clutch (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">I disagree. The only detrimental issue is the sudden no load condition on the motor. But it should not damage the clutch unless you hold it a just partially disengagged and let it slip (can you say heat buildup) but not completely release the clutch.</TD></TR></TABLE>
You would have to press the clutch faster than a human possibly could.
At 7000rpms there is no feasible clutch release point that doesn't let the flywheel skip across the clutch a few dozen times.
rody084
Mar 23, 2004 06:00 AM
ALF
Nov 30, 2001 09:58 PM
