Carb Cleaner EGR
Old Nov 29, 2007 | 08:36 AM
Acidcrakker's Avatar
Default Carb Cleaner EGR
Im cleaning out the EGR, and Im wondering if I can spray the carb cleaner into the intake manifold, where the EGR bolts to the intake manifold pipes.
Old Nov 29, 2007 | 08:55 AM
M@'s Avatar
M@
Default Re: Carb Cleaner EGR (Acidcrakker)
I doubt you will accomplish anything, besides flushing crap into your motor.
Old Nov 29, 2007 | 11:24 AM
Default Re: Carb Cleaner EGR (M@)
Well I didnt spray it in the Intake manifold. I just sprayed off the EGR itself. How do I reset the ECU to see if it did the trick?
Old Nov 29, 2007 | 11:27 AM
thisiskev's Avatar
you disconnect the battery for 30 seconds and then reconnect it. and your ecu should be reset.
Old Nov 30, 2007 | 01:20 PM
M@'s Avatar
M@
So did it work? One way you can test if the EGR will open is using some vac on the diaphram side. I just hooked it up my pie hole, and was able to check that my egr valve moved.
Old Nov 30, 2007 | 04:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">So did it work? One way you can test if the EGR will open is using some vac on the diaphram side. I just hooked it up my pie hole, and was able to check that my egr valve moved.</TD></TR></TABLE>
Cleaning the EGR helped a bit, its way less hesitation at 2.5-3 k rpms. And the CEL light comes on a whole lot less.
Old Nov 30, 2007 | 08:44 PM
prelude_93vtec's Avatar
they also make air intake cleaner also. almost the same thing i guess but thats what i used
Old Dec 1, 2007 | 05:52 PM
Default Re: Carb Cleaner EGR (prelude_93vtec)
How bout this. I keep un plugging the damn thing and it works great unplugged.
Will the EGR off an h23a1 intake manny fit the h22a?
I have a perfectly good egr on my h23a1 sitting in the other room.
Old Dec 4, 2007 | 01:36 PM
Okay so here is an update on the egr situation. I swapped EGr's and still code 12. Im drilling out the EGR ports on my h23 IM. I guess for practice. Here is the thing. I drilled 4 holes in each port, but there seem to be more than 4 holes that have been welded there are 6. Should all six be drilled. Also Im guessing that the metal they used to weld the ports is diffrent that the metal the intake mani is, cause my drill wont go through the intake mani metal. How big do the holes have to be? And when cleaning out the inside, I guess you can just carb clean everything right out of there, then tap tthe holes and call it clean?
Old Dec 4, 2007 | 01:50 PM
M@'s Avatar
M@
Well I hope you have the intake off the car first. Second I took some pics I posted in another thread.
pic:
http://www.people.ku.edu/~matt...p.JPG
The 4 ports that are inline w/ the 3 shown are the ones that need to be drilled and tapped. You need to drill through the top into the EGR passage, then use something to clean out the holes that lead from the EGR passage to the intake runners.
Beyond that I believe the only thing that will cause an EGR code is the valve being stuck closed. So if you know that the EGR that you used was working then you may have a vac. leak in the system that prevents the EGR from getting vac. If you clean the ports that dosen't address the problem.
Old Dec 4, 2007 | 02:13 PM
Lol, yeah its off the car. I did it for practice on my intake manny on the H23a1 intake mani. Does it really matter how big the holes are? I used a pretty big dril bit, mabey a 1/4 incher.
Old Dec 4, 2007 | 05:02 PM
M@'s Avatar
M@
I can't remember if the holes to the runners were that big or not, but I think if they were alittle larger they would clog up less. When I did it, I just used some pipe cleaners and the garden hose to open them up.
When drilling into the top part of the egr I was just worried about not making it big enough. I ended up with a 5/16" bolt into the holes I added.
GlenWatkins
May 31, 2006 02:46 PM
idriveadelsol7
Dec 8, 2005 11:29 PM
Vera
Feb 1, 2005 11:42 PM
DaX
May 23, 2004 07:11 AM
Louie_EM1
Mar 2, 2004 08:15 AM
