Suspension & Brakes Theory, alignment, spring rates....
Ground Control Tophats
Old Nov 29, 2007 | 08:21 AM
Weel's Avatar
Default Ground Control Tophats
How much additional travel do the ground control top hats provide?
Old Nov 29, 2007 | 11:05 AM
TunerN00b's Avatar
Default Re: Ground Control Tophats (Weel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weel &raquo;</TD></TR><TR><TD CLASS="quote">How much extra travel do they give and are they worth while. I run my racer quiet low and extra travel would be a bonus</TD></TR></TABLE>
Aprox 1" of shock travel. However, if you have a camber adjusting UCA, you'll hit the shock tower with it before you can take full advantage of the extended top hat.
I really need to take some pics of my shock tower dents one of these days...
Old Nov 29, 2007 | 12:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Ground Control Tophats (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
I really need to take some pics of my shock tower dents one of these days...</TD></TR></TABLE>
If you ever have your fenders off of the car, you should take a pic of the car on the ground to show how close your UCA's are.
Old Nov 29, 2007 | 12:37 PM
TunerN00b's Avatar
Default Re: Ground Control Tophats (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
If you ever have your fenders off of the car, you should take a pic of the car on the ground to show how close your UCA's are.</TD></TR></TABLE>
Never had the fenders off my car, unfortunately (or fortunately, depending on how you look at it, as I've never had reason to remove them).
Running 205/45-16 tires close to OEM total diameter).
Koni OTS yellows.
GC sleeves and 400 lbs/in springs.
Front equipped with GC extended upper mounts.
Front side jack points are 6" from the ground.
Front fenders have approximately a "2 finger gap".
UCA is approximately 1.5" from contact point.
Shock is 1" from bumpstop, and approximately 2.25" from fully bottoming.
At least I can never bottom out and blow my shocks. Instead, I'll blow out a balljoint one day, which is probably significantly worse.
Of course, stiffer springs would probably alleviate my issues, and will be my next change to try and help this condition.
Of course, removing my camber kit would solve all my clearance issues. Maybe I won't need nearly as much static camber with stiffer rate springs all around. 600 lbs/in, here I come...
civicnoob
Suspension & Brakes
17
Nov 25, 2007 03:12 PM
Halo
Dec 12, 2006 01:57 PM
redDA90
Suspension & Brakes
Jul 29, 2006 03:20 PM
ekim952522000
16
Sep 4, 2005 01:42 PM
llW0PllNefRex
19
Nov 18, 2003 07:40 AM
