1990 ef si build thread
CAR WAS STOLEN AND STRIPPPED
just found out the car had no windsheild wipers or windshield wiper motor had to get that and install it just did it the other day cam is down so i have no pics as of right now will get some more up soon
PS I WAS ALSO GOING THRU THE CAR TO SEE WAT WAS WRONG WITH IT AND WHY IT WAS THROWING A 20 I COULD NOT FIGURE IT OUT I HAVE NOT YET CHANGED THE FUSE BOX BUT I DID CHANGE THE COMPUTER TO A LS COMPUTER AND THE 20 WENT AWAY SO I DONT KNOW WHEN I PUT THE PM6 IN THE 20 THE 7 AND THE 5 ARE STILL THERE WHEN I PUT THE PR4 IN THE 20 AND THE 5 GO AWAY AND THE 7 STAYS HAVE NO IDEA ANY CLUES?
i was trying to lower the car yesterday and i could not get the tops of the sturts off to take the spring off any ideas on that one plz let me know thanks
SO I AM GOING TO ATTEMPT ONE MORE TIME TODAY TO GET THEM OFF SO I CAN JUST LOWER IT INTILL I GET MY KSPORTS OR MY D2S AGAIN
I NEED TO GET A MEMORY CARD FOR MY CAMERA TO TAKE PICS SO I CAN POST
Modified by Jdmefsir12 at 7:38 PM 11/30/2007
Modified by Jdmefsir12 at 6:33 AM 12/3/2007
Modified by Jdmefsir12 at 6:21 AM 12/4/2007
Modified by Jdmefsir12 at 1:09 PM 12/4/2007
Modified by Jdmefsir12 at 11:06 PM 12/7/2007
Modified by Jdmefsir12 at 8:19 AM 12/18/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboy183 »</TD></TR><TR><TD CLASS="quote">looks like you have great potential...good luck with your project
x2, but where is the tech? Move it to App/Cos
</TD></TR></TABLE>x2, but where is the tech? Move it to App/Cos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">
x2, but where is the tech? Move it to App/Cos</TD></TR></TABLE>
x2
Don't start a thread here without tech. Maybse some pics of how you got it to where it is now?
Maybe tell us what your plans for it are? Hopefully it won't stay a common JDM-front primered bucket.
x2
hes right
</TD></TR></TABLE>hes right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmefsir12 »</TD></TR><TR><TD CLASS="quote">bummmpppp
</TD></TR></TABLE>ok...so what color are you thinking of painting your car?
white or something that will be easy to take care and that will look nice it will be on some gales with sir front and rear seats half cage on some ksports wiht a single zc turbo with a brembo brake kit thats my plans right now
ok it is said that to fix the code 20 is to change the fuse junction box under the hood with one from the same car same year same trim(Si,Dx,HF) you can try that
like i said for some reason the time that i had it on my sedan it just went away by its self i never messed with it but yours might be different so try that
I have had some problems with my ef also with that stupid code 20 the first time i got it i touch the whole harness out the inside one ha and then hooked it up to the battery and hooked every thing up to it like it was inside the car and it didn't have the code 20 so i put every thing back and i did the full wire tuck and the the second time it came on one of the little clips that is in the black fuse box the one for the electrical load was bent and touching the next one to it so that why it was doing that and i just got another one the fuse boxes are all the same no differences at all dx si std not sure about ex but believe so. Ok what did your car do when u got the code 20 mine the battery would keep loosing power for some way not sure how but i would shut it of and next thing u know it would not charge the battery back up enough to start it up again. So that was fu ck up.
When I was putting my rex together and was doing the wire tuck, halfway through the tuck I tried to start the car. My grounds weren't connected by the headlights and I got the same code. I just finished the tuck and grounded everything and the cel went away. Hope this helps
