b18c1 rattling at low rpm
Old Nov 29, 2007 | 05:52 AM
97' Integra's Avatar
Default b18c1 rattling at low rpm
Hey everyone,
I just bought me an 97' Acura Integra, and at around 4 rpms or less, the engine will make a off beat ticking noise, and sounds like its comming from the engine itself, but I have no idea what could be causing it. A friend told me it is most likly the timing belt. Anyone know if that is what it could be? Cause I dont want to take it to a garage and have to pay alot just for them to look at it. I appreciate any help!
By the way I got my car from ebay
http://cgi.ebay.com/ebaymotors...wItem
Thanks,
Justin
Old Nov 29, 2007 | 05:57 AM
AWD Terror's Avatar
Default Re: b18c1 rattling at low rpm (97' Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebay &raquo;</TD></TR><TR><TD CLASS="quote">AC compressor bearing is shot</TD></TR></TABLE>
did you fix this? This could most deff be the problem.
You better fix that hood before it rust to hell.
Old Nov 29, 2007 | 06:04 AM
SoTexDC2's Avatar
If it's only a ticking noise, you might just need a valve adjustment.
Other things to check: Engine Mounts, Exhaust B-Pipe, Heat Shields, timing belt/tensioner, and any loose bolts.
Try and get a better idea of where exactly the noise is coming from, use a flathead screwdriver as a stethoscope if need be.
I Like Hondas
Sep 22, 2006 09:45 PM
Voodooboy520
Aug 2, 2006 08:41 AM
SlalomHonda
11
Dec 2, 2005 07:48 AM
ricsosan_no5
26
May 4, 2005 06:38 PM
UgotAced
18
May 23, 2004 02:48 PM
