1990 civic ef hatch with single zc throwing codes
I HAVE A 1990 SI HATCHBACK AND I WAS THROWING CODES 5,7,AND 20. I DID NOT CHANGE THE FUSE BOX BUT I DID CHANGE THE COMPUTER FROM A PM6 TO A PR4 AND THE 20 AND THE 5 WENT AWAY ANY IDEAS THEN WHEN I PUT IT BACK IN THE CODES COME BACK DONT GET IT I HAVE NOT YET CHANGED THE FUSE BOX ANY IDEAS LET ME KNWO THANKS
Modified by Jdmefsir12 at 6:35 AM 12/3/2007
when i had electric load it was cause the engine harness ground wasnt hooked up. check to make sure theres a vacum going to the map. and the tps probably just needs to be adjusted. as far as the wireing are the plugs cut off or what? and for battery just get good thick cable since it has to travel further and get a sealed battery for your saftey.
TEAM JDM-P
Aug 18, 2006 03:58 PM
