Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
body kit
Old Nov 29, 2007 | 04:47 AM
civic-cpe's Avatar
Default body kit
i had my hfp bodykit installed at the start of oct. since it was picked up in the evening, i couldn't really tell how the install looked. a day or so later, i notice there were very thin gaps between the kit and the bumper. i didnt get a chance to bring it in and almost a month later, the gaps were wide enough for a toothpick to drop thru easily. i brought it in 2 weeks ago and they said that it was installed properly and holes were drilled properly so there is no way they can pull it tighter against the bumper. i complained that its only a month and the gaps widen so much. they said to bring it back and they will try to fix it and if it doesnt work, they might need to order a new kit for me.
Old Nov 29, 2007 | 05:01 AM
GYR0's Avatar
Default Re: body kit (civic-cpe)
Is this a question? I'm not sure what you're looking for... I can go ahead and give you a general "ouch, that sucks" or "Good luck", though.
Old Nov 29, 2007 | 04:22 PM
sixonethree's Avatar
as long as they cover the cost. i got my car about 3 weeks ago with the hfp lip package installed by the honda dealer...and my rear lip is doing the same thing...theres about a millimeter gap on the rear driver side of my lip. kinda bad since i paid so much money for the real thing. planning to take it in soon, just been busy with exams. ill let you know how it goes.
Old Nov 30, 2007 | 04:27 AM
civic-cpe's Avatar
Default Re: body kit (booner47)
oops... sorry, didnt realize that my question wasnt posted. prolly accidentally deleted it.
anyway.. how much of a gap is considered normal? at the start, only 2 of 4 corners had gaps that were prolly fingernail-thin. now, all four corners have gaps that can fit a round toothpick. well, not exactly at the corner. some are at the front/rear side, and some at the side. since they said holes were drilled correctly, the the problem coming from the double-sided adhesive? are they going to redo the protection spray if they change the kit?
JDM FERIO RS
Mar 6, 2009 06:54 AM
STREETWERKZ
Honda Fit
Mar 8, 2008 04:13 PM
kcari
Honda Civic (2001 - 2005)
May 27, 2007 12:38 PM
norcal450
11
Mar 4, 2007 04:33 AM
Halo
24
Nov 21, 2004 09:27 PM
