spoon ecu
Old Nov 29, 2007 | 04:23 AM
brototoy's Avatar
Default spoon ecu
can somebody give me an info regarding this ecu? thanks! maps, vtec engagement, etc.. thanks! by the way, its obd1
Old Nov 29, 2007 | 03:03 PM
brototoy's Avatar
Default Re: spoon ecu (brototoy)
anyone?
Old Nov 29, 2007 | 08:58 PM
mtber's Avatar
1. I highly doubt you have a real spoon program.
2. Not all spoon programs were the same.
3. The only way to really tell what is programmed to the ecu is to remove the chip & read the data on it.
Hope this helps...
More then likely the "spoon" program you are running is complete **** compared to a real tune
Old Nov 29, 2007 | 09:08 PM
HRTuning's Avatar
Default Re: spoon ecu (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">More then likely the "spoon" program you are running is complete **** compared to a real tune </TD></TR></TABLE>
Ya, most of them are just JDM P30 ignition maps, fuel maps with lots of fuel added, and vtec set where it shouldn't be.
Old Nov 29, 2007 | 11:26 PM
brototoy's Avatar
Default Re: spoon ecu (HRTuning)
so stock would be better?
Old Nov 30, 2007 | 08:11 AM
HRTuning's Avatar
Yes, and getting it tuned would be even better.
Old Nov 30, 2007 | 08:13 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brototoy &raquo;</TD></TR><TR><TD CLASS="quote">so stock would be better?</TD></TR></TABLE>
if the program in the chip isn't tuned for your specific setup, and you don't have serious mods (cams, raised compression, etc) then yes the stock ECU would be much better.
Old Nov 30, 2007 | 03:01 PM
brototoy's Avatar
Default Re: spoon ecu (Relic1)
ok thanks! how about for this mods?
civic type r cams, pistons, head?
Old Dec 1, 2007 | 08:16 AM
Relic1's Avatar
at that point tuning would be required.
Randy_Adam
May 2, 2008 08:42 AM
jdm-hondacura
Dec 6, 2006 01:30 PM
an2ny888
Mar 3, 2005 01:36 AM
JdmEg6Hybrid
Mar 26, 2004 11:36 AM
spoon23_JDizM AkA SpOoN20
Oct 4, 2003 11:30 AM
