your suggestions to clean up combustion chamber/piston carbon
Old Nov 28, 2007 | 10:44 PM
xxmastermindxx's Avatar
Default your suggestions to clean up combustion chamber/piston carbon
without destroying anything, of course. i got most of it off with engine degreaser and a soft bristle brush, but some of it just won't budge. any suggestions?
Old Nov 29, 2007 | 04:05 AM
mgags7's Avatar
Don't kill yourself over getting that crap off. It's not gonna make a huge difference.
You could use a piece of emory cloth, just make sure it is +1000 grit if it is gonna come in contact with any sealing surfaces.
Old Nov 29, 2007 | 04:57 AM
Default Re: (mgags7)
now that's what i wanted to hear lol
i figured it'd be a little bit of a waste to try and get shiny surfaces
Old Nov 29, 2007 | 05:06 AM
mgags7's Avatar
Yeah man, honestly, they're nice for pictures and all, but all that work is goin down the ******* soon anyways after you put some miles on it.
Just get the major stuff out and anything that looks like it could potentially break off and be loose in there.
Old Nov 29, 2007 | 09:03 AM
M@'s Avatar
M@
Carb cleaner is the best stuff I've seen. B12 chemtool works as much as twice as well as regular carb cleaner.
Old Nov 29, 2007 | 09:36 AM
98vtec's Avatar
moderator emeritus
Default Re: (M@)
i used a wire wheel.
Old Nov 29, 2007 | 09:55 AM
PirateMcFred's Avatar
Default Re: your suggestions to clean up combustion chamber/piston carbon (xxmastermindxx)
If you're not in a hurry then you can use 100% antifreeze. It won't rust anything and i've noticed that it loosens up the carbon build up. Otherwise kerosene or carb cleaner with a small brass wire brush.
Pirate
keons5
Welding / Fabrication
24
Jul 6, 2009 10:41 AM
dave@passenger
Nov 7, 2006 08:33 AM
jdmjeff
Dec 18, 2005 08:23 PM
itralex
Sep 1, 2004 01:06 PM
dohczc
Jan 28, 2002 02:27 PM
