work wheels on an eg coupe
what will i need to fit 15x8 +30 in the front and 15x9 +33 in the rear on an eg civic coupe? what sized tire? any info would help
thanks
thanks
will they be hitting my struts? i don't mind rolling my fenders... as far as fender flares, i would only run them in the rear. is it possible to run them flush without exesive negative camber?
bump... what is the max offset and what rim diameter with what tire before hitting the struts? with extremely rolled fenders what is the lowest offset with what width of the rim and tire?
thanks
thanks
