need help on engine assembly...................
Old Nov 28, 2007 | 09:06 PM
SoSlo's Avatar
Default need help on engine assembly...................
I plastiguaged the bearings on the main to .28mm which is right where i want them. when i first torqued the mains down the crank spun freely. then if i let it sit for like 30 seconds then it wont budge without like a breaker bar to get it started then it will again turn freely by hand.
i torqued qown the mains to teh 85ft/lbs that teh ARP main studs said to. that is also where i plastiguaged the bearings.
i have never had this happen and i am wondering what to check?? or if it is just the assembly lube? have you ever had this issue?
Old Nov 28, 2007 | 11:01 PM
quicksilver1689's Avatar
i ♥ snails
85 sounds too high dude. for main bearing oil clearances on b-series goes like this
journals 1245 .0009 to .0017
.002 max
journal 3
.0012 to .0019 with a max of .0024
Old Nov 29, 2007 | 12:58 AM
D@nnY's Avatar
Default Re: (quicksilver1689)
take the arp main studs off and get new factory main bolts. If you read the info the arp main studs require you to have the motor align bored with them bolted up.
the factory specs for ls main bolts are 56 ft lbs and gsrs and type r are 49 ft lbs on the girdle and 56 on the outter caps. if the motor still doesnt spin freely you have no choice but to have it align bored
Old Nov 29, 2007 | 04:12 AM
rmcdaniels's Avatar
Default Re: (D@nnY)
What Danny said, I had to get my motor align bored/honed when I went to ARP main studs.
Old Nov 29, 2007 | 09:09 AM
SoSlo's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">take the arp main studs off and get new factory main bolts. If you read the info the arp main studs require you to have the motor align bored with them bolted up.
the factory specs for ls main bolts are 56 ft lbs and gsrs and type r are 49 ft lbs on the girdle and 56 on the outter caps. if the motor still doesnt spin freely you have no choice but to have it align bored</TD></TR></TABLE>
can i just torque down the studs to the factiory spec???
Old Nov 29, 2007 | 03:51 PM
D@nnY's Avatar
Default Re: (SoSlo)
you can but it effects the oil clearences and the bolts stretch differently then they were made for. earl told me a while back hes done it before.I would just put stock bolts new from the dealer. you do not need arp main studs
EcRzFinesT
K Series
Jun 11, 2014 09:24 PM
lupin5
May 4, 2010 04:53 PM
Herzeleid
Jan 1, 2008 09:42 AM
pentaq
Jun 9, 2006 09:40 PM
pentaq
May 31, 2006 10:10 AM
