FS/FT 2000 honda civic si LSvtec project car Nashville TN
2000 Honda civic si with lsvtec for sale for 7200 kinda firm on the price but i can work something out. this is a project car that was running but started leaking oil after i had changed the oil, not sure where it is leaking from maybe something small maybe not. other than the oil leak the car is in good shape but could use some body work it has hail dents on the roof and trunk but i have a good trunk that is the same color that will be coming with the car, also it has a big dent in the rear part of the door that looks like it was opened into a wall or something not sure how it happened it was like that when i got it.
look to sell this or maybe trade plus cash. possible trades must be 5spd and be in good running shape body work is not and issue just can't be totaled. mostly looking for 90-2000 honda or integra.
the car has lots of new parts which i will list below.
Engine
-Lsvtec with gsr head (not new)
-Gsr transmission (not new)
-New 8lb flywheel and stage 2 clutch
-new passwordjdm GSR cf intake and passwordjdm intake mainfold gasket
-new ARP headstuds
-new head gasket and valve cover gasket and cam seals
-new distributer
-new nology hot wires with ngk iridium plugs
-new JVT 1 piece header
-new aluminum radiator
-new obx blue radiator hoses
-new timing belt, water pump, and thermostat
-new alternator and belt
-new battery
-new ODB2 Catalytic converter cost $300
-used magnaflow catback exhaust
other new parts
-new headlights
-new 12000k hid
-new front calipers
-new stainless steel brake lines and clutch line
-new slotted and drilled rotors
-new brake pads
i think that is about it i might have forgotten a few things but fell free to ask any questions. also sorry for the crappy pictures, i will take pictures of anything you need, just let me know what you need to see.
Engine
-new ARP headstuds
-new distributer
-new battery
other new parts
-new headlights
-new 12000k hid
-new front calipers
-new brake pads
ChadB
Oct 8, 2004 09:08 PM
ChadB
Oct 6, 2004 05:25 PM
ChadB
Oct 3, 2004 08:47 PM
