putting 96-98 headlights on a 99-00 civic question
Old Nov 28, 2007 | 06:21 PM
Ryanrubioo's Avatar
Default putting 96-98 headlights on a 99-00 civic question
i have a 2000 civic coupe and i want to make it siR so i am gettin siR headlights and bumper, but i dont know if i need a 96-98 hood too?
Old Nov 28, 2007 | 06:23 PM
95JDM's Avatar
Default Re: putting 96-98 headlights on a 99-00 civic question (Ryanrubioo)
to put 96-98 style headlights in a 99-2000 you need more then just a hood
Old Nov 28, 2007 | 06:25 PM
Ryanrubioo's Avatar
Default Re: putting 96-98 headlights on a 99-00 civic question (95JDM)
im getting the siR bumpers too
Old Nov 28, 2007 | 06:28 PM
Libertariat's Avatar
Ek Forever y0!
You need all the body pieces on the front end.
96-98
Hood
Fenders
Grille
Bumpers
Lights
And you might need to modify the radiator support.
Old Nov 28, 2007 | 08:11 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryanrubioo &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2000 civic coupe and i want to make it siR so i am gettin siR headlights and bumper, but i dont know if i need a 96-98 hood too?</TD></TR></TABLE>
Note: There are '99-'00 SiRs too. The "SiR" bumpers and "SiR" headlights are not just from Civics with the trim SiR. In some countries those are just the normal '96-'98 bumpers, with the coupes having the bumpers we have here.
Saying you want to turn your 2000 Civic coupe into an SiR involves completely different things than what you were trying to explain because there are so many different years, trims and body styles that are called the SiR.
These cars include the Canadian SiR, which is the same as our Civic Si coupe (EM1). In Europe the SiR is a hatch or sedan with a B16A (EK4). Though those are often '96-'98 (trim levels changed names there in some countries), not all are. All of these cars are referred also to as a VTi in other countries.
You're looking for the "SiR" bumpers and "SiR" headlights though. The pieces those refer to, as explained before, are only available for the 1996-1998 years. In order to make them fit onto your car, you're going to need to replace all the parts ek forever guy mentioned.
Hope this post helped you learn a little bit.
Old Nov 28, 2007 | 08:19 PM
DCSportEJ1Civic's Avatar
Default Re: putting 96-98 headlights on a 99-00 civic question (ek forever guy)
you dont need the rad support. you can rig it. but it wont fit right. id change the rad support too. but i dont understand why you dont get parts for a 2000.
Old Nov 28, 2007 | 08:24 PM
mikesEK's Avatar
seen many 96-98 converted up ,,but never 99-200 converted down??
Old Nov 28, 2007 | 09:32 PM
NOFX's Avatar
H-T White Ops
Default Re: putting 96-98 headlights on a 99-00 civic question (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">you dont need the rad support. you can rig it. but it wont fit right. id change the rad support too. but i dont understand why you dont get parts for a 2000.</TD></TR></TABLE>
I thought it was mentioned to modify the core support, not replace it. Though replacing it would make it cleaner imo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikesEK &raquo;</TD></TR><TR><TD CLASS="quote">seen many 96-98 converted up ,,but never 99-200 converted down??</TD></TR></TABLE>
There are several really nice cars which have done the '99-'00 to '96-'98 conversion.
niccuhles was one of them.
http://www.hondamarketplace.co...78939
His car looked much better after the conversion imo.
Old Nov 29, 2007 | 12:31 AM
Default Re: putting 96-98 headlights on a 99-00 civic question (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
well is there a write up on that? cause id like to clean up my hatch. cause mine doesnt line up good at all.
Old Nov 29, 2007 | 10:00 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">well is there a write up on that? cause id like to clean up my hatch. cause mine doesnt line up good at all.</TD></TR></TABLE>
I don't know if there is a write up, but I know there's some bolts holding it on and some welding involved.
Old Nov 29, 2007 | 10:27 AM
Ek Forever y0!
I don't know if there is a write up, but I know there's some bolts holding it on and some welding involved.</TD></TR></TABLE>
Yes, there are ~10 spot welds I believe and a few bolts on each side.
The welds are easy to drill out, but you'd want to get it spot welded at some point.
Trojan Man
Northeast (Sales)
May 15, 2013 03:15 AM
.Ryan
Mar 15, 2013 07:12 PM
Ek_Barbados
Dec 27, 2012 12:07 PM
bokals
Dec 24, 2012 07:34 AM
andrewbolton
Feb 16, 2005 08:02 PM
