Honda S2000 Honda S2000
Chaning Oil??
Old Nov 28, 2007 | 06:15 PM
Babakarab's Avatar
Default Chaning Oil??
I know this is retarded but please amuse me.
I'm changing the oil for the first time on my s2k.
The jack point in the front is located where?? i cant seem to find it, i dont want to lift the car from the wrong spot and mess my new car up. pics if possible thanks.
Old Nov 28, 2007 | 06:53 PM
LAS2K's Avatar
Default Re: Chaning Oil?? (Babakarab)
You have to open your eyes first. Dude look at the pinch welds underneath. Up by the front tire there is a part which has reinforced metal. There it is viola. Don't forget to use jack stands after you jack it up.
Old Nov 28, 2007 | 10:41 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: Chaning Oil?? (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">You have to open your eyes first. Dude look at the pinch welds underneath. Up by the front tire there is a part which has reinforced metal. There it is viola. Don't forget to use jack stands after you jack it up. </TD></TR></TABLE>
To be honest, its more important to mention that you need to either a) jack the entire car up so its level on 4 jack stands or b) jack the car up on the drivers side with a emphasis to the front because the oil drain bolt is on the side of the block facing front. If you jack the front of the car up only, you wont get a drop of oil out of it.
-Todd
Edit - you could also jack up the front, remove the bolt and then carefully lower the car down on top of an oil pan, as another alternative.
Old Nov 28, 2007 | 11:06 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Chaning Oil?? (Count Blah)
you dont need a jack...
roll the car up on a piece of wood (2x4 type) and slide a pan tray under it.... yes it fits and work from up top!
Old Nov 29, 2007 | 01:02 AM
Babakarab's Avatar
Default Re: Chaning Oil?? (S@nt0s)
serious?
You can undue the the plug and replug from up top?
Old Nov 29, 2007 | 06:24 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Babakarab &raquo;</TD></TR><TR><TD CLASS="quote">serious?
You can undue the the plug and replug from up top?</TD></TR></TABLE>
yes
Old Nov 29, 2007 | 06:27 AM
ReddotsS2K's Avatar
or be like me and get a hydraulic lift
Old Nov 29, 2007 | 09:36 AM
silentdancer's Avatar
Default Re: Chaning Oil?? (ReddotsS2K)
owners manual
Old Dec 5, 2007 | 03:04 AM
tech7427's Avatar
Default Re: Chaning Oil?? (silentdancer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdancer &raquo;</TD></TR><TR><TD CLASS="quote">owners manual
lmfao.. or just take the damn car to the dealer so i can do the oil change?? w00t?
Old Dec 5, 2007 | 04:36 AM
Black S2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">or be like me and get a hydraulic lift </TD></TR></TABLE>
Im so jelouse I want one so bad. But my parents need to rebuild the garage first.
Old Dec 5, 2007 | 06:45 AM
TL1000R's Avatar
I personally use a pair of composite ramps (40.00) at O'reillys to change my oil and it actually helps because the car is slightly tilted back so the oil drains a little better and it also clears a path for the oil in the filter to hit the drain pan without hitting any other components under the car.
Old Dec 5, 2007 | 07:04 AM
Sean Juan's Avatar
Default Re: Chaning Oil?? (TL1000R)
It's common sense. Look under the car and put your education to good use.
Old Dec 5, 2007 | 07:09 AM
TheDancingPill's Avatar
Default Re: Chaning Oil?? (Sean Juan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean Juan &raquo;</TD></TR><TR><TD CLASS="quote">It's common sense. Look under the car and put your education to good use.</TD></TR></TABLE>
x2
Old Dec 5, 2007 | 07:23 AM
TL1000R's Avatar
Default Re: Chaning Oil?? (TheDancingPill)
Correct me if I'm wrong but doesn't the owner's manual clearly illustrate the methods of jacking up your car?
CivicKGC
24
Sep 29, 2007 06:37 AM
pippin65
Honda Civic (2006 - 2015)
Aug 28, 2007 10:12 PM
bluesi07
Apr 30, 2007 04:39 PM
RemerLex11
Jul 6, 2005 03:17 PM
pushinglikekrazy
Acura NSX
Nov 15, 2004 08:43 PM
