91 std shuts off while driving
Old Nov 28, 2007 | 05:25 PM
budomove's Avatar
Default 91 std shuts off while driving
Ok, 91 stock std hatch (d15b1 dpfi)
Car shut off twice on me while driving, after replacing the dizzy o ring, and adjusting the dizzy by guesswork.
3 miles down the road, the car shut off at 30mph 1500rpm
I adjusted the dizzy and tried to start after each adjustment, it just kept cranking, and finally
started after 15 minutes.
20 miles later car shut off again while coasting in 3rd at 2000rpm to a stop sign.
I adjusted the dizzy for a half hour, then did a spark test, determined no spark.
I unbolted the dizzy, pulled it off, then reinstalled.
The Car then started immediately, and has not stalled again for 150 miles.
I had my timing checked/set with a gun, it was barely off, and I also replaced the ignitor the next day.
Question #1:dizzy goes on one way(?), is it possible that my pulling off/reinstalling the dizzy fixed the problem somehow, or was that likely just a coincidence that it started right up after doing that?
Question #2:could it have been related to timing?
Question #3: I drove for a while with the dizzy plug bracket unbolted and resting on top of the tranny, could this have caused a short?
Any insights would be greatly appreciated!
Frank.
Old Nov 28, 2007 | 06:28 PM
zachvirus's Avatar
Default Re: 91 std shuts off while driving (budomove)
i was going to say its prob your main relay
was the car just randomly dying or did you casually die down?
question three, i doubt it
Old Nov 28, 2007 | 06:32 PM
budomove's Avatar
Default Re: 91 std shuts off while driving (zachvirus)
zach, main relay, I will try my spare if it dies again. what ecatly do you mean by random and casual?
Thanks for your help, frank
Old Nov 28, 2007 | 06:36 PM
zachvirus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by budomove &raquo;</TD></TR><TR><TD CLASS="quote">zach, main relay, I will try my spare if it dies again. what ecatly do you mean by random and casual?
Thanks for your help, frank</TD></TR></TABLE>
like the car die instantly and complete power loss or did it like sputter then shut down
Old Nov 28, 2007 | 06:38 PM
budomove's Avatar
it may have sputtered a little, but not much if at all.
Old Nov 28, 2007 | 06:46 PM
zachvirus's Avatar
could be the dizzy wasnt bolted prob and was bouncing around and re-aligned when you played with it but it could've been something failing electrically. next time it does it, take a test light to the wires in the plugs. could be shorting out somewhere?
Old Nov 28, 2007 | 07:07 PM
accordaffair's Avatar
I think its possible that the o-ring wasn't seated properly and the oil was then seeping into the distributor housing and causing the igniter to fail. After the oil had a chance to settle it would have allowed it to start and run. When you reseated it, it sealed properly.
Old Nov 28, 2007 | 07:18 PM
zachvirus's Avatar
Default Re: (accordaffair)
but it continued to fail after he replaced the o-ring
Old Nov 28, 2007 | 07:25 PM
budomove's Avatar
Default Re: (zachvirus)
zach is right, and no oil ever got in there, I went into the cap before and after. I also determined there was no spark when I tested all wires with a plug tester, so wouldn't that also rule out the main relay? I will go over all grounds tomorrow, and just carry around an extra dizzy, and see if it breaks down again.
Old Nov 28, 2007 | 07:37 PM
zachvirus's Avatar
Default Re: (budomove)
take the relay from the frame and test it.
Old Nov 28, 2007 | 07:43 PM
budomove's Avatar
will do, and I have a spare I will pop in if need be!
Thanks
Old Nov 29, 2007 | 06:41 PM
StorminMatt's Avatar
It could be the main relay. These tend to give out on 1988-1991 cars. With the car off, try turning the key to the on position. If you do not hear a click coming from the area of the driver side kick panel when the check engine light comes on AND when it goes off, chances are the main relay is bad.
Old Nov 30, 2007 | 07:54 AM
budomove's Avatar
Default Re: 91 std shuts off while driving (StorminMatt)
yEAH, I carry a spare, and it is good according to your test. Thanks, though.
dubyas1989
Nov 13, 2013 11:18 AM
Kelii671
Feb 10, 2010 01:51 AM
budomove
Nov 28, 2007 01:38 PM
