Which ECU to use
Old Nov 28, 2007 | 04:47 PM
00CivicGirl's Avatar
Default Which ECU to use
I picked up a replacement motor for a 90 integra. got a great deal on a b18b1 from a 94-95 teg. of course the car itself is obd0 and the motor is obd1. we are also doing a auto to manual swap.
my question is, will an obd1 ecu from a 93-93 teg run right with the 94-95 motor. personally i do not see why it wont but i just want to make sure. since we are doing the 5spd conversion, i will be gettin a 5spd ecu whichever i do get.
Old Nov 28, 2007 | 05:07 PM
freakin_eLRoD's Avatar
Default Re: Which ECU to use (00CivicGirl)
to run obd1 in your obd 0 car you need to convert it over to obd1 via obd-0 to obd1 harness or rewire.
Old Nov 29, 2007 | 04:47 AM
shuge6's Avatar
Default Re: Which ECU to use (freakin_eLRoD)
<--- 00civicgirl
so no matter which ecu i get as long as im using the obd0 wiring harness i would have to use the jumper? so use an obd1 ecu with an obd1 motor i would still use the jumper correct?
Old Nov 29, 2007 | 05:56 AM
gibsanez's Avatar
Default Re: Which ECU to use (shuge6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shuge6 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;--- 00civicgirl
so no matter which ecu i get as long as im using the obd0 wiring harness i would have to use the jumper? so use an obd1 ecu with an obd1 motor i would still use the jumper correct?</TD></TR></TABLE>
even If the engine harness is OBD1, the chassis harness is still OBD0, meaning you still have OBDO ECU plugs, so you will need the jumper harness.
Old Nov 29, 2007 | 07:13 AM
Default Re: Which ECU to use (gibsanez)
great. i understand now the jumper **** now
so will a 92-93 ls ecu work with the motor thats obd1 but coming from a 94-95 ls?
Old Nov 29, 2007 | 07:50 AM
HRTuning's Avatar
It should, ya. You could also get any chipped OBD1 ECU and have it programmed to run it. Even if it's a VTEC ECU, you just simply shut VTEC off.
Old Nov 29, 2007 | 05:44 PM
ekgcool's Avatar
Default Re: Which ECU to use (HRTuning)
00CivicGirl....Do yourself a favor and just use a 90-91 PR4 OBD0 computer. Plug and play, no need to buy jumper harnesses or 4 wire o2 sensor. The motor will run correctly with the OBD0 ECU, as long as everything is hooked up right and there are no mechanical problems. Save the cash and do a full tune-up on the motor.
Old Nov 30, 2007 | 05:30 PM
Default Re: Which ECU to use (ekgcool)
ok if we use that ecu, we use a obd0 dizzy, etc right?
Old Nov 30, 2007 | 05:36 PM
HRTuning's Avatar
Exactly.
BMFstl
Oct 24, 2010 08:57 PM
jorDAn9
Jul 15, 2008 05:29 PM
Ra GS-R
Aug 1, 2007 01:56 PM
G2integra217
May 8, 2005 11:39 PM
smashed4thgen
Oct 29, 2002 12:29 AM
