2.0L LS/VTEC
selling a 2.0L LS/VTEC longblock setup...here are specs:
LS Block sleeved by RS Machines
Forged Arias pistons
Eagle rods
Balanced and micropolished crank
ITR Oil pump
ITR Water pump
ITR bearings
Full Portflow GSR head with ITR valves
Portflow valvetrain and Portflow Titanium retainers
Stage 2 cams
BDL cam gears
Motor has '0' miles on it and is fully assembled already. Please pm me for more details and specs if you have other questions about the motor.
was selling for $4000
NOW SELLING FOR $3700 obo
will try to post pics of the motor on here asap...thanks for looking
*EDIT* Here are a couple of pics of the motor
Modified by acydphryck at 1:18 PM 2/6/2008
Modified by acydphryck at 3:21 PM 3/31/2008
Modified by acydphryck at 8:14 AM 4/1/2008
Eagle rods
ITR Oil pump
ITR Water pump
ITR bearings
Stage 2 cams
BDL cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowrider »</TD></TR><TR><TD CLASS="quote">
thanks for bump sir
</TD></TR></TABLE>thanks for bump sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM90Sleeper »</TD></TR><TR><TD CLASS="quote">$$
it's cool...thanks for the free bump anyway
</TD></TR></TABLE>it's cool...thanks for the free bump anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatnikkashoD »</TD></TR><TR><TD CLASS="quote">for 4,000.00 you can build a better and faster LS-V than that. LOL</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integratee »</TD></TR><TR><TD CLASS="quote">
free bump</TD></TR></TABLE>
thank you much for the free bump
free bump</TD></TR></TABLE>thank you much for the free bump
but then you would have to do all that work
....this guy did it for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sloej6 »</TD></TR><TR><TD CLASS="quote">
thanks very much for the vouch...for sure...putting this motor will cost way more than $4,000. Tom Fujita @ Portflow did the work on this cylinder head and i can't vouch enough for his work
</TD></TR></TABLE>thanks very much for the vouch...for sure...putting this motor will cost way more than $4,000. Tom Fujita @ Portflow did the work on this cylinder head and i can't vouch enough for his work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integratee »</TD></TR><TR><TD CLASS="quote">no its 11:22pm lol</TD></TR></TABLE>
thanks for free bump sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOL Food »</TD></TR><TR><TD CLASS="quote">compression ratio and willing to part?</TD></TR></TABLE>
compression ratio is 12.xx:1...i'll have to check the cc on the domes again to be accurate...i'll update this post as soon as i calculate the numbers. not willing to part out right now. thanks for asking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">
oh ok, i'm assuming then it'd be lower with a b16 head then? anyway, if you have a change of heart about parting it out let me know because i'd be curious to see how much you'd sell me just the shortblock for.
good luck.
</TD></TR></TABLE>oh ok, i'm assuming then it'd be lower with a b16 head then? anyway, if you have a change of heart about parting it out let me know because i'd be curious to see how much you'd sell me just the shortblock for.
good luck.
good luck.
you're correct...compression ratio would be lower with a B16 head on the block. i'll let you know if i'll part out the motor
thanks for the inquiry
good luck.
</TD></TR></TABLE>you're correct...compression ratio would be lower with a B16 head on the block. i'll let you know if i'll part out the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.OMAR »</TD></TR><TR><TD CLASS="quote">BUMP!
thanks bump
</TD></TR></TABLE>thanks bump
