4ws sticker on trunk
Theres a 4ws electronic control sticker thats under the Prelude emblem on 4ws preludes.
has anybody taken it off? if so, how did you do it?
its a factory sticker so its old and i don't want mess up the paint with random chemicals.
I've removed old stickers off the bumpers & trunk before with wd-40. Goof off is good too but, stinks bad until it evaporates & removes wax. I'd go with wd-40 first just apply it on the sticker spray it directly on in small burst & continue working at it with a clean cloth. When you get it up clean the surface with soap & water. Good luck!
Just a heads up in case you try it.....there are 2 pilot holes under the PRELUDE emblem.
Sleeper FTW! Both of my Preludes run around VTEC Stickerless!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: »</TD></TR><TR><TD CLASS="quote">Just a heads up in case you try it.....there are 2 pilot holes under the PRELUDE emblem.
I keep my VTEC badge on the car. Helps keep the ricers away.
same here. although im thinking of gettin si vtec ones and puttin em on the side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dicorp »</TD></TR><TR><TD CLASS="quote">i've heard heat gun is the best way...</TD></TR></TABLE>
Be careful with a heat gun, heat guns also remove paint.
No badges on mine either. All the holes have been smoothed also.
There is a rubber wheel, cant remember who makes it, but you can usually pick it up at most auto stores. It's kind of like an eraser that conects to your drill and it takes off decals. Worked great on my 94 Civic decals, leaves a little residue but you can clean that off with some WD-40.
Im seeing that some of you guys are saying there are holes, are you talking about under the prelude emblem because im pretty sure the vtec and 4ws stickers dont have any under
When i removed mine, i just took my time and slowly picked the sticker off with my nails, sucking on a beer will help, its a bit time consuming. Then i just used a small cloth with a little bit of metho, to remove the residue left behind. Then i put a coat of wax on top. Goodluck
cilvia
26
Feb 7, 2006 06:48 PM
