b16 crx some little problems
Old Nov 28, 2007 | 03:32 PM
cars101's Avatar
Default b16 crx some little problems
Ok so recently dropped a b16 in my crx. The day i dropped it in it seemed to run real good, no problems. When we first started it i put it in gear, while on jackstands, to see if everything was ok and it seemed good. Now i would be drving it and give is some gas to go like in second or on the parkway and would be redlining at like 7.5k. I know for a fact thats not the computers redline but i let that go. So recently I noticed the check engine light and radio would go off and come back on but the radio would lose the memory. It seems like its running the same and even goes past 8k every once in a while, actually has been goin past that for the past week. What is causing all this, please help its driving me crazy.
Old Nov 28, 2007 | 04:21 PM
JasonST's Avatar
Default Re: b16 crx some little problems (cars101)
I'm almost 101% sure it's one of ur grounds, from the sounds of it probly ur ecu ground, double and tripple check all of ur grounds and that they are TIGHT.
Old Nov 28, 2007 | 04:25 PM
cars101's Avatar
YEA boi i found my problem. MY intake was hitting the positive side battery and hitting the hood at the same time lol so it was grounding that **** out.
Old Nov 28, 2007 | 04:32 PM
SIred91's Avatar
Rainman
Default Re: (cars101)
You should be grateful it didn't burn your car to the ground.
Srsly.
Old Nov 28, 2007 | 04:40 PM
cars101's Avatar
yea i agree absolutely. I just changed the hood and this one i guess just fit better and lower. Im fixing this tommrow.
mikester1222
May 20, 2009 11:10 AM
pokerfeen12
21
May 24, 2008 07:27 AM
tRex99
Dec 12, 2004 11:17 PM
Type R
Nov 22, 2001 03:09 PM
