Does anyone know of any HOW TO writeups on how to put a crx dash in a 91 std hatch?
I just picked up a 91 STD hatch & the first thing I wanna do is put a CRX dash in it, Does anyone have or know of a writeup to help me out?
actually its a perfect fit. but make sure you take ur time. if you get the gauge cluster you have to use your wiring harness out of the hatch the crx has different plugs on it. so take the crx wiring out of the clips etc and switch em heres some pics of a 91 crx hf conversion into my 91 dx hatch. also the a-pillar covers from the rex wont work u have to use the ones from ur hatch
and make sure to get the CRX cluster mounting brackets... they are different then the civics...
make sure to get the metal bracket that the very bottom of your dash (the metal part) bolts on to. it connects your dash to your body. the crx one is different.
if you want to swap the temp controls it will be way harder... if you leave the civic ones it will be easy.
there is a little black ground that connects your dash to your steering column, make sure to undo it before you remove your dash.
one bolt on either side of the dash inside of the vent that blows on your drivers/passenger window (the vent pops out)
one in the middle on the top... and two on each side where your feet go. oh and one more 10mm in the middle behind the center console. very easy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc »</TD></TR><TR><TD CLASS="quote">
x2
You will seriously regret it if your forget this bracket. Trust me, I speak from experience.
x2
Smooth89Hatch
Jun 26, 2004 03:01 PM
