Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
shortened koni yellows
Old Nov 28, 2007 | 07:59 AM
Weel's Avatar
Default Sorted
Sorted
Old Nov 28, 2007 | 08:40 AM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
Default Re: shortened koni yellows (Weel)
TrueChoice, or Koni can do them. Not sure of the price.
Old Nov 28, 2007 | 08:42 AM
solo-x's Avatar
Default Re: shortened koni yellows (o-man)
You don't want to shorten them that much either. Get the GC upper strut mounts. Same end result, and less expensive.
Old Nov 29, 2007 | 09:50 AM
Jasper_db1's Avatar
I have Truechoice Phase-4 Koni's on my Integra. They're 20mm shorter than normal.
I use the ground control front top hats and would like to shorten the fronts another 10mm.
Old Nov 29, 2007 | 03:32 PM
B18CXr's Avatar
If a product needs to be "modified" to work in a certain application, then shouldn't you question some things??
Old Nov 29, 2007 | 03:52 PM
Crazydave's Avatar
Default Re: (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">
If a product needs to be "modified" to work in a certain application, then shouldn't you question some things??</TD></TR></TABLE>
Not necessarily....
Koni produces two different dampers for the same car..
one is the street version, the 2nd is the RACE SPSS3 (which is shortened and revalved)
Old Nov 29, 2007 | 04:29 PM
Jasper_db1's Avatar
Default Re: shortened koni yellows (Jasper_db1)
The only thing I wish these Koni's had over a true coil-over is separate ride height and preload like my Penske motorcycle shocks.
Old Nov 29, 2007 | 04:33 PM
solo-x's Avatar
Sure, and the answer is, the Koni sports were designed as a stock replacement. Damper length is same as stock. The Koni RACE units or the sports that have been shortened afterwards are more specifically tailored to cars that have been lowered.
Let me stress this again, you do not want to shorten damper length/increase shock travel by more then 25mm from stock. If you do, you will then have to use packers for your bumpstops to get the bumpstops back into a working range. That, or you turn your control arms/strut tower into bumpstops. Steel on steel doesn't make for a great bumpstop.
Old Nov 30, 2007 | 04:25 PM
B18CXr's Avatar
Default Re: (solo-x)
and so the answer lies within
Old Nov 30, 2007 | 05:59 PM
o-man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Sure, and the answer is, the Koni sports were designed as a stock replacement
and so the answer lies within</TD></TR></TABLE>
Go play with you lil green shock man
Old Nov 30, 2007 | 07:41 PM
Weel's Avatar
so how much shorter are spss3
Old Nov 30, 2007 | 09:49 PM
slammed_93_hatch's Avatar
and your teins were desinged for the JDM rice boys that can't handle a loose car....
Old Nov 30, 2007 | 09:56 PM
Weel's Avatar
Default Re: (slammed_93_hatch)
dont get me wrong I think the konis are amazing on the track. Just looking for extra travel for hillclimb situations, and it looks like extended tophats are the go for a simple solution, will make some up this week. Dont know if I am too keen on the fork mod trick though.
alot better than some JDM junk, If I didnt run koni I would run Pic performance
Old Nov 30, 2007 | 11:25 PM
pos_cd5's Avatar
Default Re: (Weel)
whats wrong with Tein other than half their line up is not track worthy as far as rates and valving goes?
Old Nov 30, 2007 | 11:31 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with Tein other than half their line up is not track worthy as far as rates and valving goes?</TD></TR></TABLE>
AFAIK, all of their lineup uses linear valving and has issues with shock fade and crosstalk in the adjusters.
Old Dec 1, 2007 | 02:47 AM
pos_cd5's Avatar
Default Re: (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">
1) whats "AFAIK" mean
2) Tein having shock fade is news to me, who claims they do?
3) what is crosstalk?
Old Dec 1, 2007 | 10:01 AM
ShaunRR's Avatar
HT White Ops
Community Builder
3) what is crosstalk?</TD></TR></TABLE>
1. As Far As I Know
2. Everyone who has taken them through multiple sweeps on a shock dyno. This is something common with most of the japanese brands, like JIC, etc. Along with that horrible linear valving.
3. Crosstalk is when an adjuster that is supposed to control on rebound, has an effect on compression, or vice versa. In a lot of brands like Tein, the crosstalk can be downright ridiculous.
Old Dec 1, 2007 | 10:05 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (Weel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weel &raquo;</TD></TR><TR><TD CLASS="quote">still instrested to know how much shorter spss3 konis are to koni sports</TD></TR></TABLE>
IIRC, its 1 inch on most Honda apps.
Old Dec 5, 2007 | 12:06 PM
STN_Pat's Avatar
Default Re: (Weel)
8041 race shocks are 25mm shorter in the front and 15mm shorter in the back, this is the 94-01 integra application (same as civic 92-95 probably)
Old Dec 5, 2007 | 07:56 PM
GBRacing's Avatar
I must say that I lost all respect for the little green spring/shock company after seeing magazine adds with *track* cars being suspended by scissor jacks. Unbelievable!
Old Dec 6, 2007 | 07:59 AM
Mleach's Avatar
Default Re: (Weel)
If by similar you mean not at all. 50 mm is ALOT to cut off the shock. You will likely only have 1.5" of useable stroke.
Old Dec 6, 2007 | 12:42 PM
pos_cd5's Avatar
Default Re: (Weel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weel &raquo;</TD></TR><TR><TD CLASS="quote">Sent the fronts away to be shortened 50mm at koni workshop, rears are recieving extended tophats
Modified by Weel at 5:56 PM 12/3/2007</TD></TR></TABLE>
might wanna fix that then.
uses0ap
Suspension & Brakes
May 13, 2009 06:15 PM
karkrazy9
Suspension & Brakes
14
Feb 17, 2009 10:43 AM
2DoorBandit
Suspension & Brakes
14
Mar 18, 2006 10:19 PM
the soL that could
Suspension & Brakes
Feb 6, 2006 06:27 PM
EK k kay
Suspension & Brakes
13
Nov 30, 2005 11:51 AM
