smoke taillights?
This is how:
http://cgi.ebay.com/ebaymotors...ZWDVW
Next time do a search. I'm sure that this has been addressed before.
painter here, to do it right....
no you dont have to take the lens off the housing.. just mask the areas you don't want paint on..but first..
remove tail lamp(s) from car..
prep with grey scotch brite lightly..
clean with alcohol based cleaner or windex...
then clean with wax and grease remover..
tack with tack rag....
then spray with adhesion promoter..(bulldog ect.)
let dry 5-10 mins..
take regular jet black base coat and over reduce it.. if normal ratio is 1:1 then do 1:1.5
spray taillights until you get the rate of darkness you want..making sure to cover all edges...
then add your regular automotive clear coat...
cut and buff as needed...
reinstall....
or take them to a trusted paint shop i usually do this for around 60 bucks a set and takes 1 day....
let dry 5-10 mins..
reinstall....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civic »</TD></TR><TR><TD CLASS="quote">painter here, to do it right....
let dry 5-10 mins..
reinstall....
i've done several lights.
i do almost all the same stuff, except the grey pad i machine sand the light with 800.
and i actually tint the clear instead of base coat. imo you can get a much smoother finish without having to sand and buff.
not tryin to start anything, just giving another approach.
let dry 5-10 mins..
reinstall....
Is there any where else besides online to find vht or anything like it? All i can find is online... I found one import shop that sells it, but they charge 32 bucks for a tiny little can that will barely maybe cover two lights. I have tried, home depot, 3 auto parts places and two craft stores including michaels. NO luck, they only have green red or blue. So please can someone help me find this stuff, cause i cant do online transactions. Thanks
Personally when im doing a smoke job I wouldn't Over-Reduce... rather id get some B/C mix clear and add a few drops of black depending on how much you're making. If you're doing a Single Stage it'd work the same way. This gives you a chance to go as dark as you want depending upon how you mix without dealing with it spraying different than it should.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SockEG6 »</TD></TR><TR><TD CLASS="quote">
I use 800 wet by hand, and add black basecoat tint to the clear till my stir stick looks like what I want my lenses to look like when I pull it out of the cup, apply med-wet coats untill it looks the way I want. I've done some with a lil pearl in them to match the color of the car as well, cool effect.
Another option though is find a guy in your area that does "3m paint protection films" on new cars. These shops also use a tinted adhesive film that is very shiny that does very very nice on taillights and its not permanant. Looks just as good as the ones I spend hours painting. They charge $75. at a local shop here to do 'em. My friend had his 05 TL A-spec done this way, very nice.
</TD></TR></TABLE>I use 800 wet by hand, and add black basecoat tint to the clear till my stir stick looks like what I want my lenses to look like when I pull it out of the cup, apply med-wet coats untill it looks the way I want. I've done some with a lil pearl in them to match the color of the car as well, cool effect.
Nocturnal
Sep 1, 2003 01:17 AM
