12 SECOND TURBO SETUP F/S
Shipping: Buyer will pay extra for the shipping charges
This comes with ALL sensors in good working condition. *** THERE ARE ABSOLUTELY ZERO LEAKS ON THIS SWAP***. I pulled this out of my car 11/15/2007 after the rebuild at 15,462 miles..
***I personally ran a 12.7 @118mph with this setup/FULL INTERIOR/STREET TIRES ONLY... thats an 11 second trap speed.. so 11's are possible with this setup. I have the timeslip to prove it also.. ********
---Oil was changed every 1000 miles with Mobile1 10w30 Full Synthetic since I rarely pulled my car out of the garage.. I've always used genuine Honda Oil Filters from the dealership.
$2500 For SWAP
-Darton Sleeved B18a block and head
-JE 8.5 pistons
-Crower Rods
-Cometic High Pressure head gasket
-ARP Head Studs
-JG EdelBrock Intake Manifold
-AEM Fuel Pressure Regulator
-Precision 880cc Injectors
-Edelbrock Pro Flo Fuel rail 5/8" bore
-Skunk 2 Cam Gears
-MSD plug Wires
-ITR Oil Pump
-B&M Fuel Pressure Gauge
-Hondata Intake Manifold Gasket --ordered brand new off Inlinefour.com
-LS Tranny -- ZERO Grinds
**Misc. - New Oil Pan gasket, may not come with MSD cap
*****Will not come with--Axles(snapped) Wire harness(need for next swap)
NO TRADES/NOT PARTING OUT
Kit comes with:
Garrett T3/T04E 60 Trim .63ar hot .63ar cold ---Ordered Brand New through Terry(Boostfed) has no lie, about 1000 miles at MOST on it.
Inline Pro Stainless Steel Dual Drilled Manifold - T3 AND T4 turbo's will bolt up to this..
XS Intercooler 24x12x3 -- ...20 pulls on the dyno before any signs of heat soak.
Tial 38mm Wastegate w/dumptube -- Ordered Brand New from Nolimitmotorsports -- has maybe 500 miles at most - just bought it very recently..
Custom Intercooler Piping made by Arnel(Thermal) -- 3in. charge (volume) 2.5in. hot side (velocity)
HKS Sequential Blowoff valve - OLD doesn't leak at all.. works perfect, sounds great.
3 inch Downpipe with Flexpipe- Made By Arnel also
MSD 6 BTM- will come with retard switch and blaster SS external coil.
**not pictured** Black Turbosmart Manual Boost Controller
$2000
Taking down a B20vtec Turbo hatch
Modified by bustedb16a at 10:07 PM 11/27/2007
$2500 For SWAP
-JE 8.5 pistons
-Crower Rods
-ARP Head Studs
-Skunk 2 Cam Gears
-MSD plug Wires
-ITR Oil Pump
Kit comes with:
$2000
