Transmission Prob! 93 lx accord slipping
Old Nov 27, 2007 | 07:49 PM
radiuslight's Avatar
Default Transmission Prob! 93 lx accord slipping
93 LX Accord Manual Tansmission
I got a new Exedy clutch because my old one was slipping
before I had a bad throw out bearing so it would slip with no shaking
The new clutch slips and shakes bad
I asked a local mechanic and he said its not the clutch
The flywheel if its been resurfaced to much would it cause this? slip and shake?
or could it be something in the transmission thats causin this problem!
Let me know where can I start!
PLEASE HELP ME I REALLY NEED TO FIX THIS PROB!!!!
Old Nov 27, 2007 | 09:58 PM
Default Re: Transmission Prob! 93 lx accord slipping (radiuslight)
Please any help would be great!
Help me out..... I'm completely lost here....someone has to have an idea!
Old Nov 28, 2007 | 09:30 AM
please help me!
Old Nov 28, 2007 | 11:55 AM
thanks for looking
Old Nov 28, 2007 | 05:33 PM
m735is's Avatar
When you had the flywheel resurfaced, how much was taken off, or what was the final thickness? Is it still within specs?
Did you use a new pressure plate, clutch and bearing with this last replacement?
Slave cylinder good? Fluid good with no air?
Any fluids leaking on the clutch to make it slip or chatter?
Old Nov 28, 2007 | 08:10 PM
Default Re: Transmission Prob! 93 lx accord slipping (m735is)
you know what
I did not check the flywheel I just installed it after it was resurfaced!
I'm begining to think the flywheel is the problem!
Yes
I got a brand new Exedy Clutch kit Disk,Plate and Bearing
I bleed the system and circulated new fluid with enough fluid in the reservoir
I checked for leaks and it seems ok no leaks everything was clean
I noticed there wasnt quite the same pressure on the pedal...before there was a bit more!
you think that has something to do with ??
Let me know
thanks
Modified by radiuslight at 6:28 PM 11/29/2007
Smcneal1970
Jun 11, 2018 06:54 AM
radiuslight
Nov 18, 2007 03:00 PM
Nixon161
Oct 31, 2007 11:07 PM
