can I run Blox hsl cams with my setup
My setup will be
1.85l Gsr motor
rs machines 81.5 itr spec pistons
acl race bearings
Gsr head machined with blox valvesprings and retainers
Will tuned with p28 hondata s200
What do you guys think . WIll hsl cams be too aggressive?
1.85l Gsr motor
acl race bearings
I don't know much about the HSL cams. I am doing a similiar build.
Itr block 81.5
Itr pistons 81.5
eagle rods
King bearings
KMS high pressure oil pump
Gsr head/port/polish by portflow
Black Nitride valves
S2 IM
68mm TB
DSM injectors
supertech springs/retainers
Blox stage 3 tuner series/S2 gears
Blox velocity stack
Obd2 to 1 jumper
converted P06 with hondata s200
saving money to buy a header(Tri Y)
I will let you know how it goes or blows!
Itr block 81.5
Itr pistons 81.5
eagle rods
King bearings
S2 IM
68mm TB
DSM injectors
Blox velocity stack
Obd2 to 1 jumper
basically same build as mine also
81.5 B18B
89MM Crank
P30 Pistons
Balanced/MicroPolished
ARP Rod Bolts
Had king bearings, but i switched to ACL
ARP Head Studs
GSR head, no port. (YET)
Supertech Valvetrain
Stock valves
Skunk Manifold
68mm TB
ITR 3inch intake with BPI stack
310 Rc/AEM rail/FPR
Action 1MS/Fidanza Flywheel
99 B16 Tranny
JDM ITR Replica Header with 2.5 Collector/Omni Test Pipe. (need a better Header
Using CROME.
I have blox B's, but evenually want to save money for pro 1's or M22x's
IMO, i think your able to to run those HSLs
your CR should be good for it.
81.5 B18B
89MM Crank
P30 Pistons
ARP Rod Bolts
ARP Head Studs
Stock valves
Skunk Manifold
68mm TB
310 Rc/AEM rail/FPR
99 B16 Tranny
)Using CROME.
im building a similar ls/vtec setup i have the blox hsl's. I havent ran them yet but from talking to my tuner those cams really come alive after 6500-7k so depends how high you plan to rev that thing. also using a higher compression by like tho itr pistons should help you out quite a bit. Imo i think it should make for a pretty stout all motor setup. on my 81.5 with b16 piston and blah blah blah he said i should make atleast 190whp my goal is 200whp so we shall see once its on the dyno.
i want to rev 9k max and make 200whp> not sure might sell it and go with smaller cams, Im just scared cams my put stress on valves.What size injectors should I use?? will the stock gsr injectors work for 200, how many whp do they max out? I want to stick with stock injectors, if not upgrade to dsm 450cc
id say youll need atleast 310cc injectors im running dsm 450s. i doubt your going to hit over 200whp with unported head and stock intake manifold. i got a ctr head wich is a factory port job and and i got a longer stroke with going with the ls crank wich help with the tq. and he still doesnt think ima quite make 200whp. but you never know till you get out and dyno it. valves wouldnt be your main worry. the stress i think would be on the valve springs but i bought supertech dual valvesprings and titanium retainers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eklsv-t »</TD></TR><TR><TD CLASS="quote">i want to rev 9k max and make 200whp> not sure might sell it and go with smaller cams, Im just scared cams my put stress on valves.What size injectors should I use?? will the stock gsr injectors work for 200, how many whp do they max out? I want to stick with stock injectors, if not upgrade to dsm 450cc</TD></TR></TABLE>
I have a set of blox B's Brand new in box forsale
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> I have an extra set of blox stage 3's new in box for sale or trade(was going to use on B20 build but ran out of money/motivation!)
95 gsr motor
blox intake mani
blox HSL cams S2 cam gears
portflow inner itr outter valve springs
acl bearings main/rod
std rs machine ITR pistons
dc 4-1 headers
aem fpr
stock injectors
tuned on chrome p28
185hp 124tq
13.8 @100 2.1 60s stock tires...
to answer your ? HSL all the way...
i dont know what peeps are talking about st1 st2 thats skunk2 terms/ bloxs goes by typeAtypeBtypeC/HSLs
Modified by tapboyzlilj at 10:27 PM 2/4/2008
blox intake mani
dc 4-1 headers
aem fpr
stock injectors
tuned on chrome p28
185hp 124tq
Chefskinny
Apr 1, 2016 01:07 AM
CRX MASE
May 3, 2006 06:06 PM
jaydmcrx
Jan 17, 2005 11:31 AM
