New time in my B16 GSR!!
2.24 60ft
14.86 @ 92.xx mph
My best in this car before was a 15.3 @ 89.xx mph
This car has 11.5 comp pistons, rods, GSR cams/head, chip, and I/H/E no cat, ACT clutch.
14.86 @ 92.xx mph
My old sig said 14.81 @ 94.55 because that's what my brother inlaw did when it was his but he had a type R intake cam in it. Now it has stock GSR cams witch is why I changed the sig to the real time it pulls sence i have had it. I guess that Type-R cam was worth 2 mph!
Oh He did have a B20 bottem end in it at one point and ran 14.1 @ 99.9 !
Ok I have to update this.
I was wrong with the 60ft above.
60ft- 2.276
330- 6.251
1/8- 9.571
mph- 73.63
1000- 12.438
1/4- 14.861
mph- 92.46
My other times were 15.031 @ 91.26, 14.937 @ 92.02, and 14.912 @ 92.40.
I love my B16 GSR almost as much as my Type-R
Modified by LDS at 11:32 PM 12/2/2007
60ft- 2.276
330- 6.251
1/8- 9.571
mph- 73.63
1000- 12.438
1/4- 14.861
mph- 92.46
Yeah, Id like to get it down to 14.6 @ 93 the way it sits but i think it will require some tuning. Some sticky tires would help also
hmm 14.8 with all that? I did 14.8 on my stock gsr. stock exhaust and everything. Had a filter at the end of a the TB thats about it. And thats with bald tires at 17 psi. Im pretty sure you can get that # down alot lower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 »</TD></TR><TR><TD CLASS="quote">hmm 14.8 with all that? I did 14.8 on my stock gsr. stock exhaust and everything. Had a filter at the end of a the TB thats about it. And thats with bald tires at 17 psi. Im pretty sure you can get that # down alot lower. </TD></TR></TABLE>
When My brother inlaw first got the car when it had the stock GSR motor he did 14.9 with the only mod being lowered. This GSR had such a stong motor in it stock, I was crushed when he called me and said he water locked it. But now it has the hi compression B16/gsr combo and yes I figured it would do better too. Maybe with this cold weather it may do a couple tenths faster.
