cluster not working after LS swap?
Old Nov 27, 2007 | 04:42 PM
sleep_Rx's Avatar
Default cluster not working after LS swap?
i just swapped a 93 LS motor into my rex and did an OBD1 conversion, it starts and runs fine. i have a couple problems though.. my tach, fuel gauge, and temp gauge aren't working, any suggestions?
Old Nov 27, 2007 | 05:02 PM
ludesrv's Avatar
Check your fuse. I'm sure some other small things aren't working that are on the same fuse.
Old Nov 27, 2007 | 05:23 PM
sleep_Rx's Avatar
i checked all the fuses, they are all good. the lights in the cluster work, but the 3 gauges don't...
Old Nov 27, 2007 | 05:40 PM
jfish360's Avatar
U sure there plugged in, good and snug? If so check to see if there getting power to the back of the cluster.
Old Nov 28, 2007 | 02:17 PM
sleep_Rx's Avatar
where does the cluster get power from? i checked all the fuses, they are all good, i also grounded the cluster to a different spot and checked the grounds in the engine bay and they are all connected tight. also the fuel gauge worked the first time i started it...
Old Nov 29, 2007 | 09:01 AM
sleep_Rx's Avatar
could there be something wrong in my jumper harness, thats the only other thing i can think of..
NazVil86
Aug 4, 2009 02:45 PM
sleep_Rx
Dec 6, 2007 01:21 PM
.BigSexy
Mar 13, 2007 09:26 PM
P@@RB@Y
Nov 22, 2006 03:29 PM
ontheline
Jul 16, 2006 09:12 PM
