1989 Thermostat Temp
In noobspeak: There's power coming to the fuse box under the hood, but unsure if power is going from that to the relay and on to the fans. First order of business is to check the relay and see if that's bad. Anyone have other suggestions of what I should check first? My dad's helping with this project and swears now my thermostat is fine.
Modified by frmrwowjunkie at 5:52 PM 11/27/2007
The fans are controled by the thermo sensor located at the bottom of the radiator
on the left side.Simple test to see if the fans work is to disconnect the connector and short the two wire together,turn the key on and the fan should run.If the fan works replace the sensor.
Mark
Mark
hmtcrxsir
Apr 29, 2009 06:48 PM
baonest1
Feb 19, 2003 02:12 PM
